I need some power
Old May 10, 2004 | 05:23 PM
marcusqb5's Avatar
Default I need some power
i need some power in my ls, im thinking about getting a turbo kit, i/e/h, pulleys,cam gears, msd ignition, but im wodering how many hp's will i be producing on a safe amount of pressure of boost, i need help, where should i start or what should i hange about my plan, kinda new to the import scene
Old May 10, 2004 | 05:31 PM
dasher's Avatar
Default Re: I need some power (marcusqb5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcusqb5 &raquo;</TD></TR><TR><TD CLASS="quote"> i need some power in my ls, im thinking about getting a turbo kit, i/e/h, pulleys,cam gears, msd ignition, but im wodering how many hp's will i be producing on a safe amount of pressure of boost, i need help, where should i start or what should i hange about my plan, kinda new to the import scene</TD></TR></TABLE>
not be be mean ... but you seriously need to do a little research before turbocharging your LS...
turbocharged vehicles don't use a header ... they use a turbo manifold.
Ditch the pulleys, cam gears , and msd ignition from your list.
You should start by reading Maximum Boost by Corky Bell and then spend 100 hours reading through the archives on Honda-tech under every topic that comes to mind ...
here is a good article I wrote myself to getv you started
https://honda-tech.com/zerothread?id=635014
Old May 10, 2004 | 05:52 PM
marcusqb5's Avatar
Default Re: I need some power (dasher)
yea true i know your not being mean but i'am new to the import scene, went from a 340 hp ss camaro to a ls integra, a big jump but im gonna listening to your advice and do some research before i do it, but how many hp's could a turbo kit add to a ls integra, and in most situations, does vtec matter? j/w?
Old May 10, 2004 | 05:57 PM
Boost Addict's Avatar
A turbo kit on an otherwise stock LS, at 6-7 psi, should give about 200-220 HP at the wheels. But it really all depends on the setup.
Old May 10, 2004 | 06:14 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcusqb5 &raquo;</TD></TR><TR><TD CLASS="quote">yea true i know your not being mean but i'am new to the import scene, went from a 340 hp ss camaro to a ls integra, a big jump but im gonna listening to your advice and do some research before i do it, but how many hp's could a turbo kit add to a ls integra, and in most situations, does vtec matter? j/w?</TD></TR></TABLE>
That's as broad of a question as it gets.
I've seen ls's make anywhere from 200whp to 500whp from a turbo.
I know your intent is probably good but you really need to read through the archives. think of a question type it in and I'll bet you'll find several threads about it already.
cletus11
Aug 25, 2011 07:39 AM
hxtasy
Jun 7, 2005 02:47 PM
GWInquisitor14
Feb 13, 2005 09:41 AM
B_1_8_hatch
Oct 12, 2003 09:17 PM
TurboB18C1
May 8, 2002 09:57 AM
