I need Info!!!! Help!!!
Old Jan 29, 2002 | 04:31 PM
R-1303's Avatar
Default I need Info!!!! Help!!!
I ordered the Drag Special from import parts with Missing link...will i have any check engine lights or run lean??? plz help!!....future mods will be 3inch pipping into apex n1 turbo, thicker head gasket, and 310 cc injectors.....managed by vafc for now is this ok?? help!!
thanks R-1303
Old Jan 29, 2002 | 04:59 PM
JM Performance's Avatar
Default Re: I need Info!!!! Help!!! (R-1303)
dont you think you shoulda figured all this out before you bought the kit?
[Modified by 00SilverLS, 8:59 PM 1/29/2002]
Old Jan 29, 2002 | 05:16 PM
clean's Avatar
New User
Default Re: I need Info!!!! Help!!! (00SilverLS)
no CEL the "missing link" is a nice check valve and lets the MAP sensor not see boost. no CEL. sounds like the setup looks nice too. good luck have fun boost rocks
Old Jan 29, 2002 | 05:42 PM
IVANITR's Avatar
The only check engine light that I can see you getting is from having no cat if you don't connect the exhaust onto the car. If you're running open down pipe, you'll have a check engine light for that. I don't think you'll run lean either unless you boost higher than 7 lbs or so.
Old Jan 29, 2002 | 05:46 PM
FBP Ex-T's Avatar
Default Re: I need Info!!!! Help!!! (IVANITR)
yea thats pretty much it....get some guages...a/f, boost, egt oo and a fpr is a good mod...thats cool...if i htink of anything else i'll let ya kno
R-1303's Avatar
thanks a lot everybody..so no cel's whew...only plan to boost about 4-7 pounds max until i get the right a/f ratio going...oh yeah ordered the oil water turbo to..
Old Jan 29, 2002 | 05:51 PM
boost killz's Avatar
New User
I would say make sure you tune the car as son as the afc goes in, because that will be your best benefit of the whole ordeal with hondas and turbo.. Tuning be the key aiiight. Peace
Nick
Old Jan 29, 2002 | 06:08 PM
R-1303's Avatar
Default Re: I need Info!!!! Help!!! (boost killz)
thanks boost...anything else i need to know.....just incase??
Old Jan 29, 2002 | 06:14 PM
FBP Ex-T's Avatar
yeah im tuning mine the day after i install it whenever that is
zachsbat1
Apr 24, 2008 05:04 PM
TRE_
Nov 7, 2004 12:26 AM
wambus
Aug 12, 2003 07:38 AM
HybridCoupe
Apr 25, 2003 10:55 PM
genop
Aug 16, 2002 05:02 PM
