engine bearings
Old Feb 18, 2003 | 01:55 PM
integra95's Avatar
Default engine bearings
I need to get some bearing for my engine. I just got eagle rods. From what i was told is that they have number 3 rods. There is the stamp letters on my crank. On the right side where the rod are, these are these letter b,a,b,b. From my reach I think the bearings i need to get is green,yellow,green,green. Now if i got these how true will these bearing be to spec and what kind of clearance do i want for a turbo car?
thank you for taking your time
Old Feb 18, 2003 | 03:01 PM
Jeff C's Avatar
Default Re: engine bearings (integra95)
Well, if your motor is an LS or B20, then they should all be green. When I called Eagle, they told me to use all green.
The ideal way to determine your bearing size would be to get 1 set (2 halves) of each color and plasiguage (sp?) each rod.
Old Feb 18, 2003 | 03:43 PM
integra95's Avatar
Default Re: engine bearings (Jeff C)
When they mark there bearing they only mark them on one half right. If its green then the bearing would be green. IS there such thin as green and yellow on the same rod.
Old Feb 18, 2003 | 04:22 PM
altoid's Avatar
plastigauge the bearings and if there is too much clearence then you know what to get from that, you'll need a manual to know though
Old Feb 19, 2003 | 07:08 AM
Jeff C's Avatar
https://honda-tech.com/zerothread?id=216667
Old Feb 19, 2003 | 09:00 AM
sgT's Avatar
sgT
all green?
dont ever take that advice.
Old Feb 19, 2003 | 09:05 AM
Jeff C's Avatar
Default Re: engine bearings (sgT)
Hindsight is 20/20.
Old Feb 22, 2003 | 08:26 AM
integra95's Avatar
If i got the same bearings will they fit? Andwhat kind of clearance do i want for a race motor?
dieselwilly
Honda Civic (2001 - 2005)
Nov 23, 2014 03:20 PM
pcguy760
Oct 4, 2011 10:16 PM
cbmlsvteg
Aug 13, 2002 12:04 PM
Sonny
Jun 12, 2002 07:24 PM
