block building question please answer
Old Feb 15, 2003 | 07:32 PM
UncleBen'sRacing's Avatar
Default block building question please answer
ok i have a bare block, and by bare i mean pistons rods, crank and block, all disassembled....
im buying the following i want to know if this is all i need in order to slap the head on and drive:
block is a LSvtec b18b (1999)
oil pump and pick up,
timing belt,
timing tensioner
intake and exhaust manifold gaskets
water pump
2 thrust washers
rear main seal
rear main seal retainer
5 upper and 5 lower main bearings
8 rod bearings
head gasket
i need all hardware (bolts)
..... my question is to finish the block what else do i need.... i have the following tell me if i cant use any of the following:
fidansa flywheel
act clutch
b16a oil pan
flywheel plate off b16a
oil squirters off b16a
oil plate that goes under crank (i forgot name) off b16a
lsvtec oil line
b16 head drilled and tapped for ls vtec
what else do i need, with LS block will the b16a oil pan be enough or not
thx in advance
Old Feb 15, 2003 | 07:42 PM
SlowPoke's Avatar
New User
Default Re: block building question please answer (AllMotorEF9)
dont forget to add arp rod and head bolts, and balance the bottom end
Old Feb 15, 2003 | 07:43 PM
black-hatch's Avatar
c-speedracing.com i dont feel like going through ur list it all sounds right thow
Old Feb 15, 2003 | 07:57 PM
Default Re: block building question please answer (black-hatch)
i have arp head and rod bolts, and main cap bolts allready
Old Feb 16, 2003 | 04:21 AM
Dual Cams's Avatar
sounds goood.
92lx
May 22, 2012 11:28 AM
SilverStreak02
May 19, 2009 06:25 PM
Garage 808 Hatch
Northwest (Sales)
31
Aug 27, 2008 08:39 PM
91whiteZCrex
Feb 26, 2006 10:05 AM
Mad Cow Disease
Mar 13, 2004 04:57 PM
