What causes boost creep?
Old Jun 26, 2003 | 10:54 AM
GraphiteAccord's Avatar
Default What causes boost creep?
The car running great for 2 weeks at .33 bar, 5 psi, solid. Went to the track friday night, did like 2-3 slow passes, then headed home. All the way home, the car would boost less and less. By the time i was home, it wouldn't build any boost. So i went through all my piping and my vaccum lines..turns out the wastegate adjustment nut came loose, and the wastegate backed off all the way. so i took it apart, and reset it. Well, it was set alittle higher then i want (8-9psi) just off the wastegate. So i head over to a friends house, an dit does the same thing, starts boosting less and less. So i get to his house, and put it back together, except lock tighted the nut. Well, ever since, it'll boost fine, untill i hit 5500 (vtec...) then it'll just over boost to 12 psi...What happened? I'll change vaccum lines again i suppose...
heres a pic of my wastegate:
Old Jun 26, 2003 | 11:20 AM
FastNFurious
Guest
Posts: n/a
A bad spring can cause it.....
Old Jun 26, 2003 | 12:06 PM
DR. ON POINT's Avatar
Banned
Default Re: What causes boost creep? (GraphiteAccord)
what kind of turbine housing is that?
Old Jun 26, 2003 | 12:13 PM
Default Re: What causes boost creep? (DR. ON POINT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DR. ON POINT &raquo;</TD></TR><TR><TD CLASS="quote">what kind of turbine housing is that?</TD></TR></TABLE>
Garret/AiRresearch
Old Jun 26, 2003 | 12:36 PM
redlinegsr's Avatar
yea try checking or changing the spring
Old Jun 26, 2003 | 09:12 PM
Default Re: What causes boost creep? (redlinegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinegsr &raquo;</TD></TR><TR><TD CLASS="quote">yea try checking or changing the spring</TD></TR></TABLE>
what should i be looking for? i have pulled it apart, everything seems fine. i'm going to try a new Vaccum line....could i possibly have it set too loose?
Old Jun 27, 2003 | 11:01 AM
i messed with it last night....adjusted the wastegate around, and rerouted the vaccum source, also put an MBC on it. I got on it once, and it was OK. Then after that, it creeps hard to 15 psi...
Could my engine timing affect it whatsoever?
Old Jun 27, 2003 | 11:19 AM
DeepSi's Avatar
timing could affect the amount of boost built. i believe if the timinig is to retarded, this can cause a lot of boost creep as the gases are still expanding in the turbo housing causing the turbo to spool faster. causing boost creep.
Old Jun 27, 2003 | 08:50 PM
Default Re: What causes boost creep? (DeepSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeepSi &raquo;</TD></TR><TR><TD CLASS="quote">timing could affect the amount of boost built. i believe if the timinig is to retarded, this can cause a lot of boost creep as the gases are still expanding in the turbo housing causing the turbo to spool faster. causing boost creep.</TD></TR></TABLE>
Guess what we did before going to the track? yea, you guessed it, retarded the timing...time to advance it back
Old Jun 27, 2003 | 09:35 PM
MiraiZ's Avatar
boost leak
Old Jun 27, 2003 | 09:41 PM
Default Re: What causes boost creep? (MiraiZ)
Ok, so i messed with the timing, it runs a bit smoother, but still boost creeps.
Miraiz, intercooler piping, or vaccum line leak? i've checked all the pipes more then once, all seem fine...
Old Jun 28, 2003 | 12:14 PM
heh, i got the boost issue taken care of from just messing with the wastegate. Now my timing is wayyy off...heh, one thing after another it seems...
Old Jun 28, 2003 | 02:00 PM
sporkcrx's Avatar
So what was the problem/solution?
Old Jun 28, 2003 | 02:02 PM
Default Re: What causes boost creep? (sporkcrx)
i messed with the vaccum lines. i had it plumbed to the compressor housing, so i moved it to my vaccum manifold, and messed witht he wastegate adjustment some more. and amazingly enough, it was all good. Then for some reason, the car would die around 55-6k or so...timing was wayyy off. so i backed the timing down and fiddled with it for about 5 minutes this afternoon, car runs great, pulls right to redline at .40 bar or so.
CX-T
Jun 19, 2008 09:22 AM
AZNracerx1989
Jul 18, 2005 10:12 AM
Racer X
Mar 27, 2003 01:07 PM
Etylorcen
Jun 4, 2002 11:50 AM
TurboIntegra
Aug 11, 2001 01:23 PM
