How are you BUILT?
Old May 24, 2004 | 06:43 AM
spark plugs.
Guest
Posts: n/a
Default How are you BUILT?
Turbo guys,
i have a 95 LS motor. i think it's about time for a rebuild. For those of you with rebuilt motors, what kind of set up are you using?Pistons, rods, sleeves, crank????
Old May 24, 2004 | 07:13 AM
civic_hatchback's Avatar
Default Re: How are you BUILT? (troublecodes)
Well im bout 6 foot 230....
Old May 24, 2004 | 07:17 AM
DD_JonnyLee's Avatar
Default Re: How are you BUILT? (civic_hatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_hatchback &raquo;</TD></TR><TR><TD CLASS="quote">Well im bout 6 foot 230.... </TD></TR></TABLE>
best reply of the day
Old May 24, 2004 | 07:28 AM
spark plugs.
Guest
Posts: n/a
Default Re: How are you BUILT? (Raped-Ape)
i KNEW some1 had to be the d1ck and take the title seriously...c'mon, can you guys just stay on topic, please.
Old May 24, 2004 | 07:41 AM
RyanEJ8's Avatar
SRP Pistons, Eagle Rods, ARP Headstuds, Golden Eagle blockguard with stock sleeves, ZEX 105300 cam and valvesprings.
Old May 24, 2004 | 07:48 AM
Old_Nocturnal's Avatar
Default Re: How are you BUILT? (RyanCivic2000)
see signature...
Old May 24, 2004 | 08:26 AM
spark plugs.
Guest
Posts: n/a
Default Re: How are you BUILT? (Nocturnal)
nocturnal, how many hp is that buildup good for?
any more suggestions?
Old May 24, 2004 | 09:32 AM
sorry but i had too.
Old May 24, 2004 | 09:43 AM
-iLLuZioN-B18C1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nocturnal &raquo;</TD></TR><TR><TD CLASS="quote">see signature...</TD></TR></TABLE>
Old May 24, 2004 | 10:51 AM
spark plugs.
Guest
Posts: n/a
Default Re: How are you BUILT? (-iLLuZioN-B18C1)
illuzions...you to0k a b18c1 and lowered it to the compression of an LS?? wouldn't it have been better to use an LS, or was there an advantage of the c1?
Old May 24, 2004 | 11:03 AM
Rod.'s Avatar
benson sleeves,stock ls crank,acl bearings,manley rods, cp pistons
Old May 24, 2004 | 11:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by troublecodes &raquo;</TD></TR><TR><TD CLASS="quote">illuzions...you to0k a b18c1 and lowered it to the compression of an LS?? wouldn't it have been better to use an LS, or was there an advantage of the c1?</TD></TR></TABLE>
ls and gsr engines are different. just b/c i got 9.1 pistons doesnt mean i have a ls block now. still got the vtec head. its just many people who want to 'eventually' run high boost will go lower CR just to be able to have that margin of error in tune,bad tank of gas, whatever it may be. pound for pound and all else equal, power in b18c1&gt;b18b
Old May 24, 2004 | 12:01 PM
spark plugs.
Guest
Posts: n/a
thanx!
Old May 24, 2004 | 10:02 PM
civickiller's Avatar
my future plans are benson sleeves, stock crank, pauter rods, cp pistons
Old May 24, 2004 | 10:09 PM
ringgold's Avatar
Default Re: How are you BUILT? (civickiller)
all stock good to about 500whp or so. SR20DET
Old May 24, 2004 | 10:14 PM
gunmetalcivic's Avatar
cp pistons and eagle rods with stock honda bearings for me
Old May 24, 2004 | 10:27 PM
dfoxengr's Avatar
as am I. lol
Old May 24, 2004 | 10:29 PM
99blackcivicSi's Avatar
Default Re: How are you BUILT? (gunmetalcivic)
Darton "MID" series sleeves sending my blocks off soon.
ACL bearings
knife edged crank
still have to order my rods, pistons going to end up at about 10.2:1 compression with 30psi
and a few other secrets that i won't mention
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">
as am I. lol </TD></TR></TABLE>
lol seems to be the adverage size of most people same here too much
Old May 25, 2004 | 05:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by troublecodes &raquo;</TD></TR><TR><TD CLASS="quote">nocturnal, how many hp is that buildup good for?
any more suggestions?</TD></TR></TABLE>
I haven't gotten it on a dyno yet... I'm waiting on a J&S safeguard before I really push the motor. fastludeh22 made 450hp @ 19lbs. last week on a similar setup, though.
Old Jun 7, 2004 | 05:38 AM
spark plugs.
Guest
Posts: n/a
anymore?
Old Jun 7, 2004 | 05:48 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nocturnal &raquo;</TD></TR><TR><TD CLASS="quote">I'm waiting on a J&S safeguard before I really push the motor. </TD></TR></TABLE>
I love my J&S.
I am soon to be runing putar rod, je or cp 9:1, benson sleve, acl bearing, apr head stud, and hks gasket. Hope she will hold
Old Jun 7, 2004 | 06:30 AM
M.A.R.C.'s Avatar
Default Re: How are you BUILT? (si2die4)
D16Z6 Block:
JE 9:1 77mm pistons
Eagle H-Beam Rods
Golden Eagle Sleeves
ARP Headstuds
Cometic Standard Headgasket
OEM Bearings
D16Y8 Head:
Crower Valve Springs
Crower Retainers
Zex 105300 Camshaft
P&P Head
3 Angle Valve Job
Stock Valves
Old Jun 7, 2004 | 08:37 AM
Soon_2b_evil's Avatar
Default Re: How are you BUILT? (CivicRyda2k)
Dart Block.
Eagle rods.
Wiseco pistons 10.5:1compression.
built head.
You'll all see it soon.
Old Jun 7, 2004 | 08:46 AM
turbo*s2k's Avatar
Default Re: How are you BUILT? (Soon_2b_evil)
GE sleeves
Eagle rods
Arias Pistons
Kid_SiR
Feb 8, 2008 09:35 PM
litovi3tboi503
Jan 15, 2007 09:00 PM
litovi3tboi503
Jan 14, 2007 07:02 PM
quicksol95
Dec 29, 2004 02:17 PM
Corinthians
Aug 27, 2004 07:06 AM
