qs. Eagle H beam rods?
Old Jan 13, 2007 | 10:29 AM
litovi3tboi503's Avatar
Default qs. Eagle H beam rods or carrillo super pro A?
Hey, I am in the market for rods.. I just order some CP pistons.. I was wondering what do you guys think about eagle H beam rods? i heard they are rated for 600-700 hp? I was going to get carrillo Super Pro-A rods which are rated for 700 hp as well.. eagle rods are 300 and carrillos are 750. is it worth the extra money for the carrillos or is it just a waste of money.. My set up will be a 85mm LS vtec.. I really need inputs if you guys have use these rods before? please let me know how they went.. I know eagle has a rep for breaking on you..
my goal pretty much is 500-600 hp
thanks alot
Old Jan 13, 2007 | 10:39 AM
93supercoupe's Avatar
Default Re: qs. Eagle H beam rods or carrillo super pro A? (litovi3tboi503)
the ealges will hold pwer, and 85mm I think is too big for a FI setup.
If anything happens, u have to get it sleeved AGAIN!!
Old Jan 13, 2007 | 10:56 AM
Default Re: qs. Eagle H beam rods or carrillo super pro A? (93supercoupe)
i guess that leaves no room for error..
Old Jan 13, 2007 | 11:03 AM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litovi3tboi503 &raquo;</TD></TR><TR><TD CLASS="quote">i guess that leaves no room for error..</TD></TR></TABLE>
nope......start off with 81mm or at the most 84mm.
Old Jan 13, 2007 | 11:13 AM
Default Re: qs. Eagle H beam rods or carrillo super pro A? (non-VTEC)
does that mean im screwed with this block?
Old Jan 13, 2007 | 11:22 AM
non-VTEC's Avatar
if it's already at 85mm then you have almost no room for error if something goes wrong......headgasket sealing on a 85mm block under boost is not gonna be very good.
im sure boosting on 85mm has been done before but it just leaves little room for tuning error.
plus....you wont notice much of a power diffrence from 83-85mm anyway....
Old Jan 13, 2007 | 11:44 AM
hmmm.. what head gasket would you prefer? for a 85mm?
Old Jan 13, 2007 | 11:48 AM
komat's Avatar
golden eagle 85mm headgasket. they are oem headgaskets that are bored out to your size
Old Jan 13, 2007 | 11:51 AM
Default Re: qs. Eagle H beam rods or carrillo super pro A? (komat)
how far would you push the 85mm sleeves? 400 hp 500? what is a safe zone for these sleeves?
Old Jan 13, 2007 | 12:03 PM
mr2mitch's Avatar
Eagle rods have proven themselves in hundreds upon hundreds of applications not just in Honda's but several other platforms. They are a great product especially for the price.
It's not the hp that you should be worried about it's ring lands and melting pistons or anything that may cause the cylinders walls to be damaged.
The reason it's an issues is because if you score the walls you can't really bore them anymore to continue using them. Once thoes are no good your pretty much SOL.
Mitch
Old Jan 13, 2007 | 12:15 PM
Default Re: qs. Eagle H beam rods or carrillo super pro A? (mr2mitch)
the sleeves will hold alot of power, but if something ever happens, then ur screwed.
U dont need sleeves for under 4-500HP anyways, so i would think ur going big.
Seeming as u already have, try to trade it to an NA guy or sell it and buy another sleeved block.I see them in the local classifieds all the time.
If u dont want to go threw the hassel, then just run it, and dont let it hold u back from making power, becuase aslong as the HG seals, then ull be fine.
Old Jan 13, 2007 | 12:22 PM
lakai_19's Avatar
hm i got the same block pritty much lets just hope we got a good tuner damn
Old Jan 13, 2007 | 12:39 PM
Default Re: (lakai_19)
ima be going to rrev in portland... hehe theyre pretty good i guess..
Old Jan 13, 2007 | 02:01 PM
zexxbo's Avatar
Default Re: (litovi3tboi503)
go with pauter rods, especially if you can find them used. i got mine for $500 used, but you can get them brand new for $700ish
Old Jan 13, 2007 | 04:47 PM
Default Re: (zeimbo)
wheres at? i havent seen those rods on HT... maybe i should look harder..
Old Jan 13, 2007 | 05:33 PM
stealthmode62's Avatar
Seems like you've already made up your mind.
Old Jan 13, 2007 | 05:44 PM
zexxbo's Avatar
Default Re: qs. Eagle H beam rods or carrillo super pro A? (stealthmode62)
i think that the reputation eagle had gotten was with its 5/16" bolts rather than its new design with 3/8" bolts which is supposed to be capable of 800whp, and ive seen many vouches pushing 600+ which no problems. however, if youre going to do a huge build and want the best of the best, i dont think you should be questioning which rod to get or if this is your daily driver and you cant afford stuff breaking. the manley rods are also really good, but similar pricerange. ive heard of crower rods breaking with 400-500hp, so id say no go on those.
check the sponsors pages and also the classifieds for pauter rods or do a search
Old Jan 13, 2007 | 10:20 PM
Default Re: qs. Eagle H beam rods or carrillo super pro A? (zeimbo)
thanks alot for the input guys... i guess I am either going to get the pauter or the carrillo super pro A depending on pricing...
Old Jan 13, 2007 | 10:37 PM
94hatchvx's Avatar
well idk about the old eagles but the new eagles are supposed to not be able to break. "theoretically" i watched a video and saw a demo on the speed channel of the strength of an eagle ron. they bent it till it was shapped like an S and it never broke. just bent, so eagle gets my vote.
Old Jan 13, 2007 | 10:51 PM
Default Re: qs. Eagle H beam rods or carrillo super pro A? (94hatchvx)
how easy did it bend? bending can be a bad thing too correct?
Old Jan 14, 2007 | 08:50 AM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litovi3tboi503 &raquo;</TD></TR><TR><TD CLASS="quote">how easy did it bend? bending can be a bad thing too correct?</TD></TR></TABLE>
you will never bendt a eagle rod....or any rod for that matter
rods generally dont bend they break before they bend....you would have to hydro lock the engine to bend it.....
Old Jan 14, 2007 | 12:59 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litovi3tboi503 &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot for the input guys... i guess I am either going to get the pauter or the carrillo super pro A depending on pricing... </TD></TR></TABLE>
the pro-A's are a lightweight rod meant for all motor apps. you want the pro-H's with carr bolts if you want to make lots of power.
Old Jan 14, 2007 | 01:59 PM
Default Re: qs. Eagle H beam rods or carrillo super pro A? (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
the pro-A's are a lightweight rod meant for all motor apps. you want the pro-H's with carr bolts if you want to make lots of power.</TD></TR></TABLE>
theres 2 version of the pro-A.. the regular ones which are lighten.. and the super Pro-A which are for moderate force induction..
Old Jan 14, 2007 | 07:02 PM
94hatchvx's Avatar
no it did not bend easy. but its w/e you want. i have used eagles in every motor i have ever had and have never had a problem. ever.
litovi3tboi503
Jan 15, 2007 09:00 PM
xQB21x
16
Nov 26, 2006 04:14 AM
koratb
Nov 24, 2006 02:03 PM
jdm2teg
Apr 7, 2006 05:41 AM
1BADGS-R
Dec 30, 2003 07:08 PM
