How would you do it. GSr block
Old Aug 20, 2006 | 08:29 AM
rdeezy78's Avatar
Default How would you do it. GSr block
I would like to know how you guys would go about this build so I would have some ideas. I will be putting a b16 head on. I want to boost like 20 lbs. So besides sleeves which way would YOU go about the build i.e pistons, rods, compression, crankshaft, and all the neccesary parts. Thanks for any good reccomendations.
Old Aug 20, 2006 | 09:59 AM
B18C Turbo's Avatar
Default Re: How would you do it. GSr block (rdeezy78)
hi!
Old Aug 20, 2006 | 10:11 AM
b16a2delsol's Avatar
hahah 20 psi and 160 hp or 20 psi and 400+ dont go by pounds kiddo..
tell us how much power you want and then we will give you reccomendations
Old Aug 20, 2006 | 10:12 AM
Schister66's Avatar
Man U FTW
HT helps those who help themselves...you need to search and ask a more detailed question...
Old Aug 20, 2006 | 03:56 PM
rdeezy78's Avatar
Default Re: How would you do it. GSr block (B16a2delsol)
I would like to build a motor that will push around 400 - 450 whp.
Thanx
Old Aug 20, 2006 | 04:37 PM
JoePSI's Avatar
I suggest you post a build and then ask h-t what they would change or do differently; atleast make the effort of doing your own research, then have some one give feedback on it.
Old Aug 20, 2006 | 04:45 PM
Danny_EJ's Avatar
I would choose
GSR block
ITR pumps
ITR cams
B16 head
Supertech valvesprings/retainers
Crower Rods
83mm CP 9:1s
Golden eagle Modified OEM headgasket
LS Crank
GSR girdle+ oil squirters
Old Aug 20, 2006 | 05:49 PM
SpdFrk's Avatar
Default Re: (Danny_EJ)
^^^ 83mm on stock sleeves?? No way it'll hold.
Old Aug 20, 2006 | 07:05 PM
0554's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdeezy78 &raquo;</TD></TR><TR><TD CLASS="quote">I would like to know how you guys would go about this build so I would have some ideas. I will be putting a b16 head on. I want to boost like 20 lbs. So besides sleeves which way would YOU go about the build i.e pistons, rods, compression, crankshaft, and all the neccesary parts. Thanks for any good reccomendations. </TD></TR></TABLE>
it all depends on how deep your pockets are. i would just do forged rods and pistons. i dont think you need sleeves though if you only wanna run 20psi just find a good tuner.
Old Aug 20, 2006 | 09:06 PM
Default Re: How would you do it. GSr block (0554)
I believe you'd be fine with just Pistons and rods like some of these guys have already said for 400-450 whp but what will you be doing most ? are you an AutoX fan or strictly drag and some street fun kinda person ? Either one your major thing is to Get a really good tune if you're keeping stock sleeves , a good tune will keep those sleeves happy for long time
JDM*BUBBLE
Jul 15, 2009 02:16 PM
on-the-line
Feb 13, 2008 04:48 AM
1baddturbosi
Aug 31, 2007 06:00 AM
dc2doi
Jul 31, 2007 10:34 PM
626ace
Mar 23, 2003 03:00 PM
