Anyone using a TurboSmart Manual boost controller??
Old Sep 7, 2004 | 07:45 AM
LudEcrous's Avatar
Default Anyone using a TurboSmart Manual boost controller??
Your experiences with it? I'm either going with that or the TurboXs HP manual bc.
Old Sep 7, 2004 | 08:10 AM
underpressure02's Avatar
Default Re: Anyone using a TurboSmart Manual boost controller?? (LudEcrous)
I used the dual stage MBC in my last car. Never had a problem with it.
Old Sep 7, 2004 | 10:00 AM
xrunner86x's Avatar
I've got the GBCV with in cabin ****. It allows some wastegate creep but holds consistant boost after the initial creeping. I am probably going to switch to an EBC so I can have preset boost levels and spool faster.
Old Sep 7, 2004 | 10:32 AM
tgreaves's Avatar
Default Re: (xrunner86x)
Im using one of their cheap boost T's and it works fine..
Old Sep 7, 2004 | 06:35 PM
powerls's Avatar
the Turbosmart Boost Tee, is a pretty nice unit. Simply in design, will never fail on you. While you are turning the ****, it clicks. Not only does this help you tune the car, but it prevents the Boost Tee from backing itself out, without having to use the lock out allen key.
The TurboXS one will work, but to adjust the boost, you have to use an allen key. And I just don't like that. Plus it has a tendency to back itself out.
Old Sep 8, 2004 | 08:21 AM
Rod.'s Avatar
Default Re: (powerls)
How much is this boost controller. My turboxs is leaking or soemthing
INCNTRL4
May 2, 2006 01:16 PM
stizzit
Feb 9, 2006 06:17 AM
5thGenCivicKid
Mar 26, 2005 11:40 PM
boostedh22a
Nov 15, 2003 07:22 PM
Tofurky
Aug 6, 2002 10:11 PM
