How to spend thousands of dollars-lots of pics
Old Nov 8, 2002 | 02:05 PM
rondigs's Avatar
Default How to spend thousands of dollars-lots of pics
I'm one of the lurkers in the background....Its taken quite awile (several years). Just trying to do everything right the first time. Im hoping to finish this summer. The motor just lacks some ARPs and a head gasket. As far as the turbo goes...everything you don't see, I need. Im located in mississippi so I'll be hitting up the florida boys for some tuning (Vaportrail). Thanks to everyone that helped thus far. Especially Geoff and Viren.
The motor is an LS/VTEC: golden eagle block 84.5mm weisco pistons, eagle rods, the block was girdled as discussed a few weeks ago (motor work done by VS racing AKA-Viren). The head has type r intake valves porcelin coated and ferrea SS oversized exhaust vales (DPR valve job), the intake and exhaust ports have been port matched and the ole P&P. The turbo is a T3 60-1 with a turbonetics stage 5 exhaust housing. And last but not least, full-race mainfold.
Enjoy....I know I will.
Motor build-up
[Modified by rondigs, 11:18 PM 11/8/2002]
[Modified by rondigs, 11:20 PM 11/8/2002]
Im a Great speller
[Modified by rondigs, 5:36 AM 11/9/2002]
Old Nov 8, 2002 | 02:14 PM
AB16A2T's Avatar
Default Re: How to spend thousands of dollars-lots of pics (rondigs)
LoL. Nice.
Old Nov 8, 2002 | 02:28 PM
falcongsr's Avatar
What is this crap?
thats a hell of a build up
good luck!
Old Nov 8, 2002 | 05:09 PM
rondigs's Avatar
Default Re: How to spend thousands of dollars-lots of pics (falconGSR)
....gotta do it right the first time
The college budget really dampens things though
Old Nov 8, 2002 | 05:37 PM
JDEM1's Avatar
nice manifold
Old Nov 8, 2002 | 08:39 PM
rondigs's Avatar
Default Re: How to spend thousands of dollars-lots of pics (G_Force_Si)
Thanks. Geoff just required that I work all summer in a sweat shop to pay it off.
Old Nov 9, 2002 | 09:35 PM
rondigs's Avatar
Default Re: How to spend thousands of dollars-motor build up-lots of pics (rondigs)
Obviously the head is built...However, I need some insight. The combustion chamber is in the stock form (I.E. not refigured for 84.5mm). WITHOUT disassembling everyhting, what can I do to improve flow. Take some edges off on the outside of the combustion chamber?
Old Nov 9, 2002 | 10:38 PM
sutrusu's Avatar
i dont see any pics?
Old Nov 9, 2002 | 11:55 PM
B18EG6's Avatar
Default Re: How to spend thousands of dollars-motor build up-lots of pics (sutrusu)
Old Nov 10, 2002 | 05:22 PM
Danger's Avatar
Default Re: How to spend thousands of dollars-motor build up-lots of pics (B18EG6)
good start .
Old Nov 10, 2002 | 05:29 PM
khang77642's Avatar
nice
Old Nov 10, 2002 | 05:57 PM
AbaZ's Avatar
Too bad it just wont stop their
I thought I would just rebuild my ZC... turns out 7 grand later I am Almost done.. lol
Jeff
Old Nov 10, 2002 | 06:47 PM
rondigs's Avatar
Default Re: How to spend thousands of dollars-lots of pics (AbaZ)
Thanks B18EG6.
Yeah, I know it doesn't stop. So many things-so little money.
Old Nov 10, 2002 | 06:49 PM
Full-Race Geoff's Avatar
looks sick man. i cant wait for it to run!
Old Nov 10, 2002 | 07:57 PM
inspyral's Avatar
Default Re: How to spend thousands of dollars-lots of pics (FFgeoff)
that milkcrate is about to buckle!
Old Nov 10, 2002 | 08:29 PM
rondigs's Avatar
Default Re: How to spend thousands of dollars-lots of pics (inspyral)
So you like my motor stand. LOL!!! Anyone have insight to the question I posted eariler?
Old Nov 10, 2002 | 08:44 PM
dont touch anything, leave the head stock. you might not think its the best thing to do, but youll thank me when your on the dyno.
Old Nov 10, 2002 | 08:50 PM
rondigs's Avatar
Default Re: How to spend thousands of dollars-motor build up-lots of pics (FFgeoff)
Pretty much the same thing viren said. Sounds good to me.
Old Nov 11, 2002 | 09:11 AM
b18bturbo's Avatar
very nice ronald. I hope this motor really turns some power. Th Girdles i can install on any LS to convert them to GSR spec. I also can drill and tap the oil squirters as well now. We just completed full b18b spec block ot GSR spec.
Old Nov 11, 2002 | 11:04 AM
2K_TEG's Avatar
Default Re: How to spend thousands of dollars-motor build up-lots of pics (b18bturbo)
Viren, can you just get GSR main caps and girdle and install it? Or is it more complicated than that?
I doubt I am going to tear down my motor again anyways.
Old Nov 11, 2002 | 11:26 AM
b18bturbo's Avatar
Default Re: How to spend thousands of dollars-motor build up-lots of pics (2K_TEG)
we dowel and machine the caps to make the even and them fit them in .same principle as what Geoff has come up with...
Old Nov 11, 2002 | 08:42 PM
turbohonda's Avatar
To put the gsr girdle on the LS block all you need to do is bolt it on with gsr main bolts and align hone it. However once you do that you will need a gsr oil pan, pickup, and windage tray.
supersilverdc2
Sep 6, 2018 10:19 AM
boostedb20z
Jul 12, 2011 09:24 PM
AcuraFreak
Aug 19, 2002 06:15 AM
