How to remove Piston from rod? (aftermarket)
Ok, I have Scat rods on wiseco pistons right now. I need to separate the piston from the rods. Because im going with a different set of rods. I see the clips on the side, but my question is how do i remove those dam clips? I know this might be a noob question but i tried to do some searching and no luck. Thanks in advance for any help.
Re: How to remove Piston from rod? (aftermarket)
good quality pick set will do wonders.. and patience is much needed .. some of those C clips and clip rings can be PITA at times..
OMG PITA!!!! I jus used a 0 fat head screwdriver, just take your time. Your should not be in a rush when working on a engine.
Ok, well how do i even take it out? Do i have to pry it out or what? Im just confused because i have a clip plyer remover that is not working. Just not to sure what you guys are actually doing to get theses out.
i used a ziplock bag and a screw driver. How else do you think our going to get them out lol Yes you have to pry them out. Or take them to a shop and have them swap the rods for you because putting them in, well you guessed it, another PITA!!!
LOL. DAM!! i guess im going to the shop then!! i was trying to avoid this. Anyways i am trying to pry it out and those dam clips does not want to move!!
EnzoSpeed
08-09-2005 03:17 AM
