wastegate flange help
Old May 16, 2010 | 01:56 PM
gman105's Avatar
Default wastegate flange help
All,
I purchased a custom turbo manifold from Canadia a while back. I was told it was flanged for a 44 mm wastegate. However, my TiAl v44 does not fit it. At all. The file that I have attached (or tried) shows a rough sketch of the flange.
Any ideas on what it is for or if a conversion exists for my TiAl product?
Thanks,
Gman105
Old May 16, 2010 | 03:49 PM
azandford's Avatar
Default Re: wastegate flange help
canadia ftw!
Old May 16, 2010 | 05:10 PM
Adriano's Avatar
I'm 99% sure that whoever built that manifold welded the outlet flange on, not the inlet. The inlet flange doesn't have that lip on the inside, it's recess in.
Adriano
Old May 16, 2010 | 05:12 PM
Adriano's Avatar
See if it bolts up to the outlet on the wastegate
Adriano
Old May 17, 2010 | 04:45 AM
gman105's Avatar
Just checked and it fits perfectly against the outlet of the wastegate. The only problem is that the 70mm OD portion makes fitting a clamp on impossible. What the heck?
Any other thoughts? And yes, Canadia ftw.
Old May 17, 2010 | 07:39 AM
gman105's Avatar
Can anyone verify that this is not the flange for another wastegate manufacturer such as turbosmart or synapse?
T25So
Dec 22, 2005 03:07 PM
5STAR3
Jun 29, 2004 10:51 PM
accordfreak
Aug 29, 2003 03:39 AM
simike
Aug 19, 2002 03:25 PM
