how often to replace?
Old Jun 19, 2005 | 09:35 AM
twenty's Avatar
Default how often to replace?
how often do you guys replace the o2 sensor? b/c im pretty sure it fouls out faster since the car is boosted?
Old Jun 19, 2005 | 11:35 AM
s2kdre's Avatar
Default Re: how often to replace? (standard staples)
as long as you dont get no cel you're ok, once in a while you can take it out and clean it with brake cleaner to get the carbon build up off.
Old Jun 19, 2005 | 12:45 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standard staples &raquo;</TD></TR><TR><TD CLASS="quote">
how often do you guys replace the o2 sensor? b/c im pretty sure it fouls out faster since the car is boosted?</TD></TR></TABLE>
my primary senros lasted 65k.. i'm using my secondary now.. it has ~ 90k miles, if you have a/f gauge, abnormal readings should give a clue. when mine went, everything was reading lean out of the sudden.. if you're using obd1 managment, you can use either one of sensors like i am.
Old Jun 19, 2005 | 02:46 PM
N20civicB18's Avatar
Default Re: how often to replace? (jdmhonda)
ummm I dont think brake clean is safe for o2 sensors but im not sure
mortificationrock
10
Mar 26, 2008 08:23 AM
Morty
Jul 17, 2007 11:49 PM
Gunmetal_B20_Hatch
13
Aug 11, 2006 09:49 AM
tianporn
Aug 10, 2004 08:37 PM
youngkow
Dec 31, 2002 01:10 PM
