How often does a EBC give problems?
Old May 31, 2012 | 05:58 AM
  #26
kbouchard1092's Avatar
Default Re: How often does a EBC give problems?
Not unless you overboosted, Thats what boost cut is for tho
Old May 31, 2012 | 06:55 AM
  #27
spectacle's Avatar
Originally Posted by LightningTeg
The sintered filter on the mac solenoids is known to clog up with soot and cause issues. I had that happen once so I dont run the filter anymore.
Originally Posted by Muckman
I found that the filter gave me more consistent resolution. In terms of duty = pressure increase.
Pretty opposing views here. What is the purpose of the filter on the Mac's? I haven't run one on my car for over 2 years and I don't think I have a problem, but I'm curious to read more about it
If anyone has any real world knowledge, please share
Old May 31, 2012 | 08:20 AM
  #28
Supply air to the valve needs to be free of contamination. Too much contamination can cause the air valve to stick, leading to valve failure. Keeping the supply air dry is also very important. Too much moisture in the air can also cause the valve to stick.
Basically if you are using a filter and it clogs then that would be the reason He took it off. If the filter is clogged its not going to let air escape causing creep issues. They really shouldnt clog most come 1/8 Npt and are a flat stone filter....You could buy a bigger cone shaped stone filter if clogging was a issue. I think alot of that may depend on where the valve is placed in regards to the clogged filters (near dumptube, high moisture areas ect)
They were designed with a stone filter for a reason.
Old Jun 1, 2012 | 09:27 AM
  #29
spectacle's Avatar
Good info. Thanks
Old Jun 2, 2012 | 04:47 AM
  #30
Skalabala's Avatar
Yes good info
Thanks
discombob
May 17, 2010 09:30 PM
Running925
Apr 25, 2009 07:48 AM
fro
Sep 30, 2004 09:25 PM
KamikazeSol
Feb 15, 2004 04:28 PM
Teg4e
Jan 9, 2004 12:34 PM
