how much will it handle???
Old Jun 11, 2007 | 10:11 AM
tics's Avatar
Default how much will it handle???
hi guys im from the united kingdom and im doing a b18c4 turbo build in a ej9 hatch but the problem is no one over here can sleeve the blocks so i was wondering what horsepower and psi i can run safely and reliably.this will not be a daily driver only a weekend car.the setup is as follows:
wiseco low compression pistons
carillo steel rods
acl bearings
cometic low compression head gasket
arp rod bolts
arp headstuds
new oem honda valvetrain
peakboost turbo kit(t3/t4 or t3/t60-1 not decided yet which do you think?)
all help will be much appreciated guys.
p.s it will be tuned on hondata s300
Old Jun 11, 2007 | 10:33 AM
carnot's Avatar
Default Re: how much will it handle??? (tics)
are those wiseco pistons going to be forged? If so I don't think you will be able to run them on stock sleeves. I think the real question you need to ask yourself is what hp number are you shooting for? It is much easier to pick a power goal and then build an appropriate type of motor as opposed to making a list of parts and asking yourself how much hp will this make. There are just too many variables with the latter approach. Hope this helps
Old Jun 11, 2007 | 11:41 AM
doood's Avatar
been there done that
Default Re: how much will it handle??? (carnot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carnot &raquo;</TD></TR><TR><TD CLASS="quote">are those wiseco pistons going to be forged? If so I don't think you will be able to run them on stock sleeves. </TD></TR></TABLE>
wtf?
no information is better than wrong information
to the OP; with that build list 350-400whp would be within reach, assuming the fuel system can handle it and the tune is good.
Old Jun 11, 2007 | 03:04 PM
atec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carnot &raquo;</TD></TR><TR><TD CLASS="quote">are those wiseco pistons going to be forged? If so I don't think you will be able to run them on stock sleeves. I think the real question you need to ask yourself is what hp number are you shooting for? It is much easier to pick a power goal and then build an appropriate type of motor as opposed to making a list of parts and asking yourself how much hp will this make. There are just too many variables with the latter approach. Hope this helps</TD></TR></TABLE>
I think you are refering to the H22 stock FRM sleeves.
They will have a problem with regular forging.
(Didnt mahle make pistons for the SS H22??)
B18 sleeves will handle forged pistons without any problems.
With a good tune you shouldn have a problem maxing your turbo.t3-t04e or t3-t60-1
Just make shure you are picking the correct size injectors and a good fuelpump.
and of course choose a known tuner that you know do his work properly.
the engine can break on 250-300whp with the wrong guy behind the laptop
atheworld0
Feb 4, 2016 01:13 PM
b_hoov
Jan 17, 2009 11:31 PM
Powelly
Sep 26, 2007 04:22 PM
seanc520
Oct 17, 2006 06:08 PM
GSRerrr
Apr 4, 2005 07:11 PM
