How much tuning necessary?
Old Oct 10, 2006 | 08:55 AM
loopedR6's Avatar
Default How much tuning necessary?
Im dropping my turbo set up in later this week and then im shipping my ECU over to xenocron to get chipped. With them having all my specs, once they chip my ECU will the car run fairly well for a while with out getting it dyno tuned, or do i need to get it tuned immediately? i do realize that tuning is a must but im about out of funds is why i ask.
Old Oct 10, 2006 | 09:28 AM
urbansi's Avatar
Default Re: How much tuning necessary? (loopedR6)
The problem with sending your ECU away is that every car is different as well as the turbo setup... You cant tune a car correctly without throwing in a wideband, dataloging, checking plugs, and changing timing...
its like phone sex, it just doesnt work
Save your time and money and have your tuner/shop chip the ECU and either have it street/dyno tuned all at the same time.
Old Oct 10, 2006 | 09:33 AM
adseguy's Avatar
The car will run fine, probably rich from 2 cars I've seen off his basemaps (perfectly fine). Don't boost and get to a tuner as soon as you can....no rush, but I bet you'd like to save gas. The problem with you not having enough funds is not a good sign. With a boosted moddified honda you need a little buffer if something happens (axel, clutch, injector, etc). You'll need a little money on the side just in case something happens and you need this car .
Recap: Don't boost (not even once to risk it) and get it tuned ASAP
Old Oct 10, 2006 | 09:46 AM
loopedR6's Avatar
Default Re: How much tuning necessary? (adseguy)
as far as the buffer goes, ive also got a 97 4runner so if the car goes down and i have to wait for a pay period to fix it then i can. thanx for the input. another question. the setup that i bought from the guy here on ht comes with a missing link. on my DA my map sensor is firewall mounted instead of on the tb. can i use this missing link or will i have to do something else?
Old Oct 10, 2006 | 09:56 AM
adseguy's Avatar
You will be removing the missing link and run the map sensor as normal. Now if I understand right the "setup" you bought uses a missing link, but "your" car has a firewall mounted map sensor. If so, is that a 3 bar or 2.5 bar map sensor? You need to know these things as well as the missing link problem .
Old Oct 10, 2006 | 10:15 AM
loopedR6's Avatar
This is what i bought:
Ss autochrome mani..braced (has worked great for me)
T3 thunderbird turbo . great size and rebuilt, no problems
ss oil lines
turbonetics evolution wastegate
2.5 inch dp with o2 bung, and no ground clearance issues.(can see it on car)
All intercooler piping is 2.5 inches
Hks ssq bov
vacum manifold
johnyracecar intercooler..perfect fit under front bumper support
Fmu
two different fuel pumps..one brand new 255 walbro intank, and a msd inline high pressure
Also have a 2.5inch rsr ex mag exhuast included if wanted
so he said he also tossed in the missing link so that i wont throw a CEL and go into limp mode. im really not surewhat bar my map sensor is. its the stock 92 GS map sensor.
EastCoastRust
Engine Management and Tuning
Aug 8, 2014 06:17 PM
lookout22
Apr 23, 2009 01:16 AM
NA JDM GSR
Jan 24, 2007 06:22 PM
94vtecmn
May 6, 2003 12:31 PM
turbopanda
Oct 21, 2001 04:26 PM
