how much psi?
Old Jun 1, 2003 | 12:08 PM
scttydb411's Avatar
Default how much psi?
just made my mbc/bleedervalve and turned up my boost 2 more psi to 8psi. still runs safely rich and no detonation with my 6psi settings on my safc hack. how much psi can i safely crank it up on my tdo4L and d16y7? setup is obd2 d16y7, tdo4L off '02 wrx, 450cc dsm/resistor box, safc, msd btm -.33degree/lb, starion fmic. i want to crank it to 10psi to be closer to 200whp, but i don't know if the stock rods/pistons/cylinders will take it. i knew that this would happen-turbocharge then want more.
what does everyone think on the stock internals? 10psi safe, or should i stick with 6-8psi? (i will take it to the dyno to tune for 8-10psi, btw)
Old Jun 1, 2003 | 12:32 PM
Adriano's Avatar
Default Re: how much psi? (scttydb411)
9-10lbs would be a safe umber. Make you have it dyno tund, that helps alo.
Old Jun 1, 2003 | 12:44 PM
b16ahybrid's Avatar
Yeah you should be fine runing 10psi if you tune it on the dyno like you stated.
masterEF
Nov 10, 2009 05:56 PM
Full-Race Geoff
Nov 17, 2005 04:35 PM
project civic
Apr 26, 2005 07:49 AM
DOHCarp
Aug 23, 2003 04:17 PM
M.A.R.C.
Mar 9, 2003 03:28 PM
