How much oil to put in...
Old May 27, 2002 | 09:57 PM
CM-R's Avatar
Default How much oil to put in...
I have a drag 3 GSR and i just did an oil change...i put in 4 quarts of 10w30 royal purple....should i have put in 4.2 quarts of oil since i have a gsr??...Does it really matter??...i checked my dip stick and the oil is about half a centimeter or less below the very top dot of the oil stick...
Old May 27, 2002 | 09:58 PM
VaporTrail's Avatar
New User
Default Re: How much oil to put in... (CM-R)
honestly, you should be fine
Old May 27, 2002 | 10:17 PM
PrecisionH23a's Avatar
i usually keep my oil level midway between the empty and full dots on the stock dipstick.
Old May 27, 2002 | 10:18 PM
DIRep972's Avatar
Smarter than you
Default Re: How much oil to put in... (GudeH23a)
Old May 27, 2002 | 10:24 PM
Flamenco-T's Avatar
Default Re: How much oil to put in... (DIRep972)
and don't over fill it....by doing it,. you can block the oil return flange on the oil pan causing the oil to get backed up in the return line...
I always tried to re-check it after a few miles of driving around after an oil change
Old May 27, 2002 | 10:29 PM
Default Re: How much oil to put in... (Flamenco-t)
too much oil also blows oil seals on your turbo.
Old May 27, 2002 | 10:53 PM
CM-R's Avatar
thanks guys for the info...So do you think i should just keep it at that level or should i just add a tad bit more oil??
Old May 28, 2002 | 12:38 AM
shadowdawn's Avatar
ack I have a tad above the 2nd dot on the stock dipstick, or in other words 4.2 quarts of oil.
Old May 28, 2002 | 12:55 AM
inspyral's Avatar
Default Re: How much oil to put in... (shadowdawn)
As long as you're above the MIN dot, I wouldn't worry about it.
Old May 28, 2002 | 07:49 AM
GruvyTune's Avatar
New User
agreed!
keep it toward the lower dot. Too much oil definitely impeded flow into your return fitting. Filling your oil to the top of the fill line will have your oil level about 1/4 way up your return hole fitting the way most of us have ours drilled.
I noticed during oil burning smells after hard boosting especially after when braking when that hole will be essentially covered in oil. the oil returning from the turbo is not just a stream of oil coming down that tube, its a froth wipped up by the bearing.
EG_Civic_Si
Feb 6, 2011 04:05 AM
highwhey
Nov 11, 2010 05:53 AM
EGgoJDM
Dec 1, 2009 12:05 PM
