How much to NOTCH a block?
I got EAGLE rods and i have to notch the D16 block. The machine shop quoted me $150-200. That seems like a lot, is that right?
Following the article by TOO, can I just mark what has to come off and have them do it that way? Prolly cheaper...
at the jetties fishin'
Re: How much to NOTCH a block? (maztur)
do it yourself with a high speed dremel. it's super easy. All you do is put the crank in the block and a piston/rod and rotate until it hits...then dremel away that block material until it no longer hits.
then just clean the block out real good and you're done. I've done it several times on ford stroker kits. super easy.
Re: How much to NOTCH a block? (stackz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz »</TD></TR><TR><TD CLASS="quote">do it yourself with a high speed dremel. it's super easy. All you do is put the crank in the block and a piston/rod and rotate until it hits...then dremel away that block material until it no longer hits.
then just clean the block out real good and you're done. I've done it several times on ford stroker kits. super easy.</TD></TR></TABLE>
Yea, I'm just scared ...
check out this site. http://www.theoldone.com/artic..._tips/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur »</TD></TR><TR><TD CLASS="quote">
Yea, I'm just scared ... </TD></TR></TABLE>
Just attempt it yourself. A bare D-series block is what...$75?
Re: How much to NOTCH a block? (JMinSi2000)
I said **** it to the machine shop and I did it myself ... one cylinder took me like 1.5 hours but it clears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JMinSi2000 »</TD></TR><TR><TD CLASS="quote">
Just attempt it yourself. A bare D-series block is what...$75?</TD></TR></TABLE>
tell ya what... go ahead and try it yourself, if ya mess up, which i doubt, you can have my old d16 block for $50
