How much hp out of a h22a turbo
My brother has a fully built H22a in an 95 Accord, he has the following stuff:
P&P head w/ port matched manifold
Ferrea Valve springs, Retainers, SS Vlaves
Je 9:1 cr pistons
Crower Rods
Darton Sleeves
Qaufie LSD
Clutch Specailty stage 4 clutch
Clutch masters flywheel
Precision T3/T04 60 trim turbo
Drag piping w/ Hks bov
Tial 35mm wastegate
2.5 inch dwnp w/ 3inch exhaust
Seimens 750cc injectors
Hondata s200b
We just installed the hondata yesterday and after about 20+ runs on the dyno we finally put down only 315whp and 290tq @ 15psi. The engine area was real hot from all the pulls we did.(we started with 188whp). I am wondering if this sounds close to right for this setup. This was also on pump gas. And in a Accord what do you think it should run on slicks if it ran a 15.0 on street tires.
Je 9:1 cr pistons
Crower Rods
Darton Sleeves
Qaufie LSD
Tial 35mm wastegate
Hondata s200b
Re: How much hp out of a h22a turbo (importtuner)
your probably having the same problem that gudeh23 had, where his stock ignition just fell flat on it face. Did u upgrade your ignition system at all?
I am a bad person
Re: How much hp out of a h22a turbo (flip1199)
It doesnt seem like the Hp figure is right. With that turbo on h22 it should be closer to the 400hp range at 15psi event at 9:1 compression. might just be a tuning issue.
Re: How much hp out of a h22a turbo (MotorMatrix.com)
i don't know i have a h23 nonvtec at 12psi i made 337whp and 313wtq with a t3/t04e 57trim
in my car i ran mid 13's with a stock h23 and a 50 shot and a h23 only has 160hp
so i had to be under 200whp with that ,first past 13.6@100mph
but i see h22's not make good power all the time
1fastgsrturbo
08-04-2003 06:42 AM
