how much boost on stock b16a1
i just bought a b16a1 for my 88hatch.. n was wondering how much boost i would be able to run on it all stock with 3inch exhust.. lookin to run a homemade set up with.. with a t3/t4 will be incooled too.. thanks.. sorry for newbe question search didnt work
Too many variables. With a proper fuel setup and tuning you are safe putting down 250whp to 300whp on pump gas. Of course you have the chance of your ringlands going and causing further damage. Some people here put down 300whp on a stock bottom end for a year plus and others for a couple months before the ringlands go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shotty »</TD></TR><TR><TD CLASS="quote">I have a 3mm headgasket and blockguard and have pushed ~21psi through a completely stock bottom end on a B16 on 93 octane.</TD></TR></TABLE>
Probably not recommended though!
Turbo size is a factor with how much boost you can run
t25@10lbs<t3/t4@10lbs
so 10psi i should be pretty safe.. i was thinkin bout gettin the jg intake mafoild with 8 450cc injectors.. n a fuel pressure regulator n a bigger fuel pump.. n a thicker head gasket... think that be safe for 10-12 psi... if so how long would it last before i need a rebuild
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qksl2 »</TD></TR><TR><TD CLASS="quote">It's not the power that kills, it's the cylinder pressure.
Ian</TD></TR></TABLE>
Yes, but by creating more power, you create more cylinder pressure, so just stay under 300 whp on the stock block and you should be ok.
10psi with a well tuned hondata on my stock block lasted 3 weeks! but with over 14psi boost spikes (damn delta wg + drag mani...)
I felt the motor slowly stress more and more... even if I got rid of the boost spikes, I would run no more then 8psi daily if you want to be safe. 10psi for a max setting if you have a controller.
PM-Performance
Feb 26, 2003 09:26 AM
