how much boost h/p with your darton sleeves
Old Aug 18, 2003 | 08:28 AM
oday's Avatar
Default how much boost h/p with your darton sleeves
How much boost and horse power are you running making with your darton setups and how bout some 1/4 times.
Old Aug 18, 2003 | 08:41 AM
93LSivic's Avatar
Default Re: how much boost h/p with your darton sleeves (oday)
HP and 1/4mile times has absolutely nothing to do with what sleeve you are running. Doesnt matter if its stock, Darton, GEM, RS, Benson, Leitner&Bush, DART, backwoods redneck.
Old Aug 18, 2003 | 12:45 PM
oday's Avatar
Default Re: how much boost h/p with your darton sleeves (93LSivic)
THANKS FOR STATING THE OBVIOUS. THE REASON I WAS WONDERING IS I AM USING DARTON SLEEVES AND I WANT TO KNOW HOW MUCH BOOST HAVE BEEN ABLE TO RUN AND WHICH SETUPS THEY USED. THE 1/4 TIMES IS JUST CURIOUSITY.
Old Aug 18, 2003 | 01:56 PM
viprcr1's Avatar
you have darton sleeves and you don't know how much boost you can run. im pretty sure your not gonna be running over 30psi beucase you asked this question so you have nothing to worry about.
Old Aug 18, 2003 | 07:06 PM
oday's Avatar
Default Re: how much boost h/p with your darton sleeves (viprcr1)
ok I was curious as to what others have done starting with the same block. But you are right I will not be runnung 30 psi. If you know any one that has ran 30 psi with these sleeves let me know. I would like to see that. And yess I know that top fuel rated these sleeves to 60psi but Bret Rau runs 30psi in his car and he has a solid BLOCK.
Modified by oday at 1:31 PM 8/19/2003
Old Aug 18, 2003 | 08:52 PM
T-sohctec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oday &raquo;</TD></TR><TR><TD CLASS="quote">THANKS FOR STATING THE OBVIOUS. THE REASON I WAS WONDERING IS I AM USING DARTON SLEEVES AND I WANT TO KNOW HOW MUCH BOOST HAVE BEEN ABLE TO RUN AND WHICH SETUPS THEY USED. THE 1/4 TIMES IS JUST CURIOUSITY. </TD></TR></TABLE>
Does it smell like bullshit in here?
Old Aug 18, 2003 | 11:01 PM
Foozball26's Avatar
Default Re: how much boost h/p with your darton sleeves (T-sohctec)
they'll handle anything you throw at em, leave it at that.
Old Aug 18, 2003 | 11:47 PM
flip1199's Avatar
Default Re: how much boost h/p with your darton sleeves (Foozball26)
don't worry bout the sleeves. They can handle 60lbs. But finding rods and pistons that can handle 60lbs is another story...
OT, But i was wondering if everyone makes sleeves out of ductile iron, then y can't pistons, and rods be made out of ductile iron??? If they did make them wouldn't they have the potential to withstand about 50lbs???
Old Aug 19, 2003 | 01:07 AM
liam821's Avatar
Default Re: how much boost h/p with your darton sleeves (flip1199)
your sleeves will outlast just about every other engine part you have. Sleeves you dont have to worry about.
liam
Old Aug 19, 2003 | 04:31 AM
oday's Avatar
I think ductile IRON is to heavy for pistons????THINK
I am running je 84mm 9-2-1 forged pistions with crower 4340 rods. Head is all crower except hayame cam gears and Taking suggestions for camshafts. Drag turbo kit. Don't know what kind of fuel managment ecu&gt; or size injectors I will be running yet. Still looking. Open for suggestions. Engine will be dropped into a 93 cx stripped to 2 front seats. What do you think I'll run. 6 puck clutch DH-Racing fly wheel amnd dh-racing will be handling the pp
ys1 cable tranny will be used. I don't like the hydro feel.
HOW MUCH BOOST WITH WHAT INJECTORS AND ENGINE CONTROL????
Old Aug 19, 2003 | 05:35 AM
SuperTeg95's Avatar
Does anyone know anything about the Darton stage 2 sleeves, as far as their boost limit might be?
Old Aug 19, 2003 | 12:14 PM
flip1199's Avatar
Default Re: how much boost h/p with your darton sleeves (SuperTeg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTeg95 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know anything about the Darton stage 2 sleeves, as far as their boost limit might be?</TD></TR></TABLE>
About 50lbs.
Old Aug 19, 2003 | 01:14 PM
15psi of fun's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oday &raquo;</TD></TR><TR><TD CLASS="quote"> Engine will be dropped into a 93 cx stripped to 2 front seats.
HOW MUCH BOOST WITH WHAT INJECTORS AND ENGINE CONTROL????</TD></TR></TABLE>
93 and cable tranny don't get along
Old Aug 19, 2003 | 03:00 PM
liam821's Avatar
Default Re: how much boost h/p with your darton sleeves (EFrollingout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFrollingout &raquo;</TD></TR><TR><TD CLASS="quote">
93 and cable tranny don't get along </TD></TR></TABLE>
Well you have to convert the car from hydro over to cable. Its not too hard. You need a new clutch peddle assembly and then some cables.
liam
Old Aug 19, 2003 | 09:19 PM
oday's Avatar
Default Re: how much boost h/p with your darton sleeves (liam821)
jdmshit.com and hasport have the hydro to cable conversion.
Old Aug 19, 2003 | 10:10 PM
shermanyang's Avatar
are you gonna run at ROCKFALLS with your setup? hope to see you there.
Old Aug 20, 2003 | 04:19 AM
oday's Avatar
Default Re: how much boost h/p with your darton sleeves (shermanyang)
I'll be at rock falls next year but at midway this fall.
Old Aug 21, 2003 | 08:02 PM
oday's Avatar
any1 else bump
Old Jun 5, 2022 | 01:00 PM
Smoney69420's Avatar
I'm running 27 psi on built 1.8 b18c fully built non sleeve making 600 but it's in the process of being sleeved will be right around 700 for this summer will be pushing 36psi
Dark19Acura
Oct 21, 2008 01:12 PM
vtakef
Apr 20, 2006 03:55 PM
ttracing03
Apr 1, 2006 02:43 PM
I8ayellowcrayon
Jul 8, 2003 11:37 PM
Pinhead
May 18, 2002 09:05 PM
