lsvtec boost
Old Sep 11, 2006 | 01:24 PM
vti96's Avatar
Default lsvtec boost
whats up every1 a an lsvtec with eagle retainers, wiseco pistons ,pep valves,pep valvesprings and titanium rods ,gsr cams ,68 mm tb, and a custom intake manifold no sleeves i would like 2 know how much boost i can run and what kind of power 2 expect thanks 4 the info
Modified by vti96 at 2:47 PM 9/11/2006
Old Sep 11, 2006 | 01:30 PM
vtekthis's Avatar
Default Re: lsvtec boost (vti96)
Eagle makes Titanium rods??
Old Sep 11, 2006 | 01:47 PM
vti96's Avatar
Default Re: lsvtec boost (vtekthis)
sorry my bad i meant titanium retainers
Old Sep 11, 2006 | 02:39 PM
97gsrki's Avatar
kind of an open ended question. most will tell you no run more than say 350whp or around that, but of cousre there are the occasional (not so occasional anymore) 600whp stock sleeve motors. its really up to you if you want to risk it or how conservative you want to be. anything is possible.
Old Sep 11, 2006 | 02:55 PM
AllMotorMark's Avatar
350whp is easy to be made as long as its tuned properly,
what about turbo size???
with a good size turbo 10-12psi will get you 350 whp or more
but there are alot of variables
Old Sep 12, 2006 | 02:27 PM
vti96's Avatar
Default Re: lsvtec boost (AllMotorMark)
i don't have a turbo yet so what kind of turbo and how big should i get i would like 2 make over 400whp
Old Sep 16, 2006 | 07:58 AM
vti96's Avatar
i think i might go with a gt35 or a 60trim turbo what do u guys think and is it possible 2 get around 450whp at 18-20psi?
help me out i nned some opinions thanks
Old Sep 16, 2006 | 11:41 AM
vaporboy12's Avatar
my freinds overbored stock sleeve motor finally gave out at 30psi of boost on a pt67 dbb it took 6 pulls at 30psi and the sleeve finally cracked
Old Sep 16, 2006 | 02:53 PM
vti96's Avatar
Default Re: lsvtec boost (vaporboy12)
so i should be good for 18-20 psi
and how much power did he make before the sleeve let go?
Old Sep 16, 2006 | 03:22 PM
vaporboy12's Avatar
dont know it was street and track tuned never saw the dyno
Old Sep 16, 2006 | 03:59 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vti96 &raquo;</TD></TR><TR><TD CLASS="quote">whats up every1 a an lsvtec with eagle retainers, wiseco pistons ,pep valves,pep valvesprings and titanium rods ,gsr cams ,68 mm tb, and a custom intake manifold no sleeves i would like 2 know how much boost i can run and what kind of power 2 expect thanks 4 the info
WTF !!!!!!
EddieCRX
Feb 17, 2012 05:53 AM
my crx is rhd
Dec 27, 2004 12:59 PM
my crx is rhd
Sep 30, 2004 01:40 PM
EG-6Ghost
Jun 12, 2004 07:50 AM
99teggsr
Jun 21, 2003 12:20 PM
