how much boost can i run on this set up
Stock Ls Bottem ENd
Stock Gsr Head
GOlden EAgle LSvtec Kit
Arp Head Studs
Ngk Iridum Spark Plugs
310cc Injectors
JRSC w/jrsc fmu set up
Was GOing TO run 5psi But Can i Run 10 Without Hondata or engine management like that
Stock Gsr Head
Arp Head Studs
310cc Injectors
Re: how much boost can i run on this set up (boosted92)
UHHHH iridium spark plugs and 10 PSI sweeeeeeeeeet. Kaboom. uhh no i wouldnt run 10 PSI with that charger and no inter/after cooler, and get colder plugs. run low boost with that set up and with JRSC run low boost..........always.
Re: how much boost can i run on this set up (crxsir29)
they are colder plugs , ill stick with 5psi but is there anyway to set up some kind of intercooler
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsir29 »</TD></TR><TR><TD CLASS="quote">**** it ill get alil juice some1 remove this please thanks for the help</TD></TR></TABLE>
Nitrous requires retarded timing and accurate fuel delivery, just like the JRSC does
Adding nitrous isn't going to fix anything.
Sh4rky
04-02-2002 01:34 AM
