Increase the boost for JRSC
Old Dec 16, 2001 | 09:47 PM
volkracing99's Avatar
New User
Default Increase the boost for JRSC
Hi, I just wonder does anyone know how to increase the boost for JRSC?
My current boost is 6psi, on 93 civic ex.
I heard that i can get up to 10psi? but i don't know how...
thanks....
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Increase the boost for JRSC (volkracing99)
I wouldnt do it because you have no way of intercooling it.
art
Old Dec 16, 2001 | 09:53 PM
ck279's Avatar
Default Re: Increase the boost for JRSC (Arturbo)
Jackson Racing sells an 8 PSI pulley, and Endyne's pulley I believe is for 9 LBS. You do not (can not) have to intercool at 8 PSI. You will need larger injectors, Cartech/Vortech/Comptech FMU, JR MAP mod, and JR BTC. One heat range colder spark plugs and a lower temp thermostat are also highly recommended.
You can skip all of the band aids and get a stand alone engine management system like Hondata. In the end they are very similar in cost but the Hondata is infinitly more tuneable and is less likely to have failure.
In actuality all you need to go to 8 PSI is to retard the timing and get the 8 PSI pulley........but don't expect your engine to last very long.
Old Dec 16, 2001 | 09:57 PM
New User
I have the Water Injector... is that help?
Old Dec 17, 2001 | 08:28 AM
Blown90hatcH's Avatar
Water injection helps, but you still need more. I wouldnt go 10psi with a stock Sohc motor though. Build it and you can get a machine shop to make you a custom pulley for any size. You might want to look into getting a bigger crank pulley.
Old Dec 17, 2001 | 08:41 AM
98Psi ITR's Avatar
Default Re: Increase the boost for JRSC (Blown90hatcH)
Didn't someone make a homemade boost controller for the JRSC?
Old Dec 17, 2001 | 09:06 AM
chri5's Avatar
Default Re: Increase the boost for JRSC (98Psi ITR)
Actually it is a boost LIMITER. With an SC you have to have the pulley which will allow you to build the amount of boost you want to run. ie If you have a 6 psi pulley, you will only run 6 psi regardless of what you set the EBL to. But If you have a 10 psi pulley you can Limit the boost to 6 psi
Old Dec 17, 2001 | 09:50 AM
xxplosif1's Avatar
Default Re: Increase the boost for JRSC (Strng1dah)
my friend had a fully built B16a with the jrsc @ 10 psi....he was using prelude injectors. Everything seems to be fine...
spedo
Nov 8, 2010 05:52 PM
sleeprcivic12
Dec 24, 2004 02:21 PM
2K Teggy
Oct 16, 2003 06:26 PM
Ski2001
Dec 10, 2002 04:36 AM
