How much boost?
Old Feb 18, 2013 | 07:12 PM
hybridmiklo's Avatar
Default How much boost?
I am currently running b20vtec stock block with arp headstuds. I installed my old sohc setup garret t3 super 60 turbo with tial 38mm wastegate and blowoff using hondata s300. I have only driven it up to the gas station never passing 3k rpm. I would like to make 300hp or close with this setup. The wastegate currently has a 6psi spring. How much psi should I do to make this power and not stress out the motor nor turbo?
Old Feb 18, 2013 | 07:14 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: How much boost?
That is something for your tuner to answer!
Old Feb 18, 2013 | 07:21 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
you can not judge hp by lbs of boost
Old Feb 18, 2013 | 07:27 PM
thats why i posted the motor and turbo size. i want to know so when i get to the tuner i have the correct spring for what power i am looking to make. please, experienced people only chime in
Old Feb 18, 2013 | 07:45 PM
MR.johnson's Avatar
Again. Call your tuner and ask. Some people can make a lot more or a lot less depending on the tune.
Old Feb 18, 2013 | 07:47 PM
OneBadTurboCRV
Guest
Posts: n/a
Closer to the Max efficiency of that turbo - probably 13-15psi... either way after 15psi it will start falling off efficiency map. It really does depend on the tuner though, and how much you want your tune to be on the edge.
Old Feb 18, 2013 | 08:00 PM
im very experience sir! no matter what you have no one can say how much you can make until you hit the dyno. all i know is...itll be +1 of whatever you have now
Old Feb 18, 2013 | 09:04 PM
Ok. Im going to just bring different weight springs with me to the dyno and see where it ends up while still staying on the safe side. thanks
Old Feb 18, 2013 | 09:05 PM
turbohatch96y7's Avatar
lol
see sig
Old Feb 18, 2013 | 09:14 PM
wantboost's Avatar
Who is Mr Robot?
Wanting 300hp out of a straight t3 60 trim is pushing the turbo to its very limit.. don't be surprised if you don't make 300hp
Old Feb 18, 2013 | 10:32 PM
You really need to figure your vacuum pressure at idle and go from there to determine what spring to start with otherwise you will be paying your tuner a lot of coin for things you could have done for free! Boost controller or just wastegate?
I don't have experience but I have read and read for the past two years to know what needs to be done. And I can guarantee the only thing my tuner with be charging for is a tune!
Old Feb 18, 2013 | 10:35 PM
ive heard others say the same about my turbo. I know its on the small side. Im using just the wastegate.
Old Feb 19, 2013 | 04:12 AM
OneBadTurboCRV
Guest
Posts: n/a
...and it shows. What you stated is ONLY for the BOV and assumes you don't have an adjustable one.
OP - I already gave you your info. Get a 1 bar spring and take it with you. You will need it. If you rather listen to the peanut gallery then so be it, join them.
Old Feb 19, 2013 | 06:40 AM
MR.johnson's Avatar
are you serious? sorry but your wrong.
we made 440whp on 16psi on a dynodynamics with a peakboost kit, 10.5:1 and crower cams.
Old Feb 19, 2013 | 06:56 AM
TheShodan's Avatar
Moderator
Are you sure you mean T3/T04E 60 "trim" (52lbs/min)? THAT's about 440whp. Not the T3 "Super 60" (35lbs/min) wantboost is referring to.
Just trying to clear up any confusion between the two before it gets ugly..
Old Feb 19, 2013 | 09:09 AM
MR.johnson's Avatar
lol. maybe. its just the cheap turbo that came with the peakboost kit. so yes i was talking about the t3/t4.
Old Feb 19, 2013 | 12:18 PM
OneBadTurboCRV
Guest
Posts: n/a
If you would have read the very first post in this thread there would have never been any confusion.
Old Feb 19, 2013 | 12:58 PM
TOO.MUCH.BOOST.'s Avatar
Atleast 30lbs of boost...... Just to be on the safe side.
punkracer
May 2, 2014 11:06 AM
crvtectim
Feb 14, 2012 12:54 PM
GTEC913
May 4, 2008 06:20 PM
PIC Performance
Jan 24, 2006 08:58 PM
rice is nice
Aug 24, 2005 09:39 AM
