skunk2/blox intake manifold users, how did you deal with this problem?
Re: skunk2/blox intake manifold users, how did you deal with this problem?
well i was actually going to use it, and run it to the FITV, and then have my buddy tig up the redundant port on the water outlet to avoid have to worry about any potential future problems from "caps" dry rotting and failing.
Cut it, plug it, bore it and re-weld it on the side if you can't rotate it.
its just press fit you can always pull it out too and then run a tap in there and get a big barb fitting. My old blox had that I used it no issues, just bend it up a little
I had the same issue! I called Blox and sent them pictures they responded to me and told me to send it back. I sent it back and they said nothing was wrong....I shaved down the housing to make it work.
Sprockets
09-11-2016 09:10 AM
dj theoretic
04-09-2008 05:48 AM
