How to mount a GM 3 Bar MAP Sensor?
Old Mar 23, 2004 | 10:31 PM
Hoosier Daddy's Avatar
Default How to mount a GM 3 Bar MAP Sensor?
Hey guys, I got all the wiring information from Hondata's website, but how do you actually mount the 3bar map sensor? My stock MAP is mounted on the throttle body. Any help would be appreciated.
Old Mar 23, 2004 | 10:43 PM
porsche997dc2's Avatar
Default Re: How to mount a GM 3 Bar MAP Sensor? (Hoosier Daddy)
you will have to get the pig tail for the gm map sensor and run the oem map sensor wires to the pig tail and plug the pig tail to the gm map sensor. You can let the oem sensor unplug. I like to use aluminum to make a tamplate mount it close to the throttle body but on the fire wall.
Old Mar 23, 2004 | 10:44 PM
sneakypete's Avatar
I made my own mounting bracket and mounted it to the firewall using two self tapping screws. I used two L shaped brackets that I bought at hardware store. I found them in the door hinch section. I've also seen people just use two self tapping screws and mount it directly to the firewall using no bracket at all.
Old Mar 23, 2004 | 10:52 PM
Default Re: How to mount a GM 3 Bar MAP Sensor? (sneakypete)
Thanks guys. I ordered the pigtail as well. So the GM map sensor doesn't need to be mounted a certain way? Can I leave the stock map sensor in as it will now be defective, or should I take it off?
Old Mar 23, 2004 | 10:59 PM
sneakypete's Avatar
I left my stock map sensor in place.
Old Mar 23, 2004 | 11:01 PM
So just splice into the stock harness from the pigtail, and plug the GM map sensor into the pigtail, then unplug the stock map sensor?
Old Mar 23, 2004 | 11:08 PM
sneakypete's Avatar
Yup, that's it.
Old Mar 23, 2004 | 11:14 PM
Awesome. Thank you!
Old Mar 23, 2004 | 11:24 PM
sneakypete's Avatar
No problem. GL
Old Mar 24, 2004 | 11:53 AM
Phaze2 Mike's Avatar
Doesnt the gm map sensor need to be attached via a vacum line? It just doesnt sit with an open nipple.
Old Mar 24, 2004 | 11:57 AM
dennis's Avatar
sounds like you got it, but FYI http://hondata.com/3barinstall.html
Old Mar 24, 2004 | 12:16 PM
Muckman's Avatar
Moderator in Chief
Default Re: How to mount a GM 3 Bar MAP Sensor? (dennis)
someone post some pics of it installed!
Old Mar 24, 2004 | 12:33 PM
M.A.R.C.'s Avatar
Default Re: (yellowfever)
yes it needs a vacuum source to that nipple
Old Mar 29, 2004 | 06:09 AM
So, if you have a throttle body mounted map sensor, where do u source the vacum lead that goes the the GM nipple?
Old Mar 29, 2004 | 07:33 AM
kpt4321's Avatar
Anywhere coming directly from the intake manifold will work.
Old Mar 29, 2004 | 07:42 AM
b16ahybrid's Avatar
Default Re: (kpt4321)
all your doing is replacing the stock map with a 3bar map. Easy as that.
Just unhook the stock map, mount the 3bar and hook the vacuum up to it. you already have the splicing down, so your set.
Old Mar 29, 2004 | 08:45 AM
5thgencivic's Avatar
Default Re: How to mount a GM 3 Bar MAP Sensor? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">someone post some pics of it installed!</TD></TR></TABLE>
I used zip ties to mount mine It might not be clean, but it does the job...
Old Mar 29, 2004 | 08:57 AM
PM-Performance's Avatar
Default Re: How to mount a GM 3 Bar MAP Sensor? (5thgencivic)
i mounted mine to the firewall using 2 long sheetmetal screws. works great and is clean as you can get. \it is mounted where the evap plug was.
heres a pic wit red silicone hose.
heres another pic further away with black silcone hose. its right between the fuel filter and the resistor box
Old Mar 29, 2004 | 09:06 AM
So just use the evap hose lead correct? Thats an easy alternative to threading a nipple into the old slot.
Old Mar 29, 2004 | 09:10 AM
huh? i dont have the evap stuff anymore and figured id use that room up for my 3bar. i have the vac source i think off the back of my manifold, everything else is off my vac block .
Old Mar 29, 2004 | 09:22 AM
Nextelbuddy's Avatar
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">huh? i dont have the evap stuff anymore and figured id use that room up for my 3bar. i have the vac source i think off the back of my manifold, everything else is off my vac block . </TD></TR></TABLE>
yup same as me
Old Mar 29, 2004 | 09:37 AM
01ITR#700's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sneakypete &raquo;</TD></TR><TR><TD CLASS="quote">I made my own mounting bracket and mounted it to the firewall using two self tapping screws. I used two L shaped brackets that I bought at hardware store. I found them in the door hinch section. I've also seen people just use two self tapping screws and mount it directly to the firewall using no bracket at all. </TD></TR></TABLE>
Thats word for word exactly what I did. For the vacuum source, I got a badass little map sensor blockoff plate that had a 90 degree brass fitting on it and just ran that to the 3-bar on the firewall.
M
Old Mar 29, 2004 | 03:05 PM
sneakypete's Avatar
Default Re: How to mount a GM 3 Bar MAP Sensor? (01ITR#700)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01ITR#700 &raquo;</TD></TR><TR><TD CLASS="quote">
M</TD></TR></TABLE>
Two great minds think alike, haha.
Old Mar 29, 2004 | 03:10 PM
WOW this thread blew up with some useful information. Thanks guys
Old Mar 29, 2004 | 03:18 PM
2muchPSI's Avatar
Default Re: (Hoosier Daddy)
good info, thanks
H22EG'z
Sep 22, 2009 06:52 PM
da9blk1
Jan 16, 2008 05:04 AM
jmeyer99
Nov 6, 2006 07:07 PM
killa_lude
Dec 28, 2003 07:09 AM
1.8T_EG
May 12, 2003 09:58 PM
