My setup..how much psi you think i can push?!?
Ok..here's what I got to rebuild my motor with
What I have now:
B18C1 motor (gsr)
Fmax turbo (ditching the mf2 and extra injector tho.)
Weapon R fuel regulator
Apexi VAFC (just gonna use it for gauge since I'm going hondata)
Apexi AVCR
What I bought:
JE 9:1 .02 overbore pistons
RC 550 Injector w/ clips
Eagle Rods
AEM Fuel Rail
Built GSR Head (port and polish..etc)
Skunk2 Intake Manifold
Hondata 2b
Steve (SGT) is going to tune Hondata for me and how much PSI you think I can boost w/ this setup? is 18 pushing it?!?
Jeff-
[Modified by ProjectD2-Jeff, 10:50 PM 11/13/2001]
What I have now:
B18C1 motor (gsr)
Apexi AVCR
What I bought:
Eagle Rods
AEM Fuel Rail
Hondata 2b
Jeff-
Re: My setup..how much psi you think i can push?!? (ProjectD2-Jeff)
You'll lean out at at 18psi, get 720cc injectors if you want that. 18psi on stock sleeves is not a good idea... but go ahead and try
Dustin
Dustin
Re: My setup..how much psi you think i can push?!? (dustin)
dont ya think that's a little overkill for 11's? hehe
sheesh.
isn't ~15psi what stock sleeves can handle?
Tom
sheesh.
Tom
Re: My setup..how much psi you think i can push?!? (Tomakit)
Tomakit & Dustin are right - ~15 psi is about all the stock cylinder sleeves can handle. The rest of you setup looks good, though. If you have to take the motor to a machine shop for the P&P anyway, you might as well have them resleeve it while its there. You would have to anyway if you run 18 psi and your sleeves start to crack.
Good luck.
Good luck.
Banned
my friend was pushing 430 hp to the wheels (i think 18psi) on a stock block. no blockguard, nothin. he had aem rods & arias 8.5:1 pistons.
11 second daily driven. speed pro management.
[Modified by immortal, 7:45 PM 11/13/2001]
Re: My setup..how much psi you think i can push?!? (immortal)
That is NICE immortal!
Good thing this question was asked, I was wonder what the stock sleeves could handle.
Smarter than you
immortal- how do u know that guy? was that car built at joetech? is the owners name Ruben? is he from Texas? I swear thats his car.. I used to think that was the tightest integra ever
Re: My setup..how much psi you think i can push?!? (DIRep972)
Stock sleeves can take a whole lot if you don't do any agressive tuning. I've seen them hold together on motors that run 25psi all the time (with blockguard). As long as the motor is healthy and your fuel and timing maps aren't crazy, you'll be fine.
Re: My setup..how much psi you think i can push?!? (Incognito)
Jeff-
Smarter than you
cool cause there setups are almost exacrly identical except Rubens kit was all custom, no drag piping.. other then that it looked exactly the same.. same green with leather and same JDM front end.. damn
damn kurt, i was looking at those pics and i was like, "Damn thats hella like Nirmal's car!" then i realized you posted it lol.
Re: My setup..how much psi you think i can push?!? (Chris_Turbo)
Jeff-
If you are gonna do a blockguard, you might as well just sleeve the bitch while its out...
c'mon, you know you want to...
15, bahhh, you need you some 20+psi...
(do it, do it, do it) hehe
Tom
Tom
shhhh....don't tempt me
Well, the problem I have w/ sleeving is that I have to send my block out and blah blah blah...it takes too long and I want my car to be on the roda SOON! Hehe..I might just get me another b18c5 motora nd build that one up and just swap it once that one is done
Jeff-
Jeff-
you can run whatever you want PSI wise, but if you lean out once at high PSI its all over for the cylinders, I have run well tuned LS blocks with rods and pitons but stock block at 24 PSI, DFI tuned and very carefully. Cylinder pressure does not increase linear when making power, like pressure will not go from 1000 to 2000psi just from double the boost, this will only happen when you knock or from preignition, try to get spark lightoff at 12 degrees after TDC this will help prevent the rods going straight down onto the crank which will givw you crazy high cyl pressure.
Re: My setup..how much psi you think i can push?!? (Liltrix)
Try 11 seconds without slicks.... then we have something..
<---- jake who hates people comparing times when they darn well that noone drives around with slicks on the street!!!
Re: My setup..how much psi you think i can push?!? (GSRwBOOST)
that's what i'm saying! 11 sec now days aren't special @ all..but to hit 11's w/ full interior plus street tires will be something!
Jeff-
Jeff-
