how many lbs. do stock eclipse's run?
put a vacuum/boost gauge on a stock dsm and it will be 12psi tyler..
We are not refering to the factory pedal pressure gauge that doesnt even measure ****..
Hardly man, the 2g BOV leaks at around 12psi. As someone mentioned stock they run around 10-11psi usually, and with the restrictor removed from the BCS they run around 11-12.
Sean EH2
Jul 5, 2004 07:18 PM
