how to manually retard timing on d16y8
Old Mar 14, 2003 | 06:17 AM
extrmeboost's Avatar
Default how to manually retard timing on d16y8
yes i searched, and i didnt come up with much. i have the set-up to run about 10 psi daily, but for now im only running 7psi i want to retard the timing at the distributor but im not sure how.
Old Mar 14, 2003 | 06:18 AM
Tony Starks's Avatar
Default Re: how to manually retard timing on d16y8 (extrmeboost)
Rotate it towards the front fo the car.
EDIT: "of" I can't type for **** today.
[Modified by Tony Starks, 3:19 PM 3/14/2003]
Old Mar 14, 2003 | 06:24 AM
Default Re: how to manually retard timing on d16y8 (Tony Starks)
about how much, and should i do it with the car running, if so , how the hell do i do that thing to "blind" the ecu
Old Mar 14, 2003 | 06:33 AM
EE_Chris's Avatar
You will want to jumper the same connector used to show the engine codes. This will remove any timing advance the ECU is using. Make sure your idle speed is set correctly and that the engine is warm.
You can do this with the car running, however, you should have a timing light instead of guessing.
Old Mar 14, 2003 | 06:35 AM
Default Re: how to manually retard timing on d16y8 (EE_Chris)
Yeah what he said. In case you don't know where the service connector is, its right above the ecu. A lime green rubber boot will be holding it. Just pull it out and bridge the two sides with a tool of your choice.
Old Mar 14, 2003 | 06:54 AM
brcivic411's Avatar
paperclip
Old Mar 14, 2003 | 07:44 AM
Default Re: how to manually retard timing on d16y8 (brcivic411)
cool thanks
Old Mar 14, 2003 | 09:30 AM
swrdply400mrelay's Avatar
What exactly does this mean? Thanks
Old Mar 14, 2003 | 09:48 AM
EE_Chris's Avatar
Default Re: how to manually retard timing on d16y8 (swrdply400mrelay)
When you set the timing via the distributor, you are setting the base timing value.
As rpms are increased, there is less time to ignite the a/f mix, thus advanced timing is needed. There are other parameters that play into the final timing value, just giving an example of one.
Answer the Q?
Old Mar 14, 2003 | 09:50 AM
home_made_turbo's Avatar
http://www.c-speedracing.com has a great write up on how to adjust your timing.
ewilliams1990
13
Aug 17, 2013 06:09 PM
b20z2
Aug 8, 2005 11:57 AM
dimotorsports
Mar 22, 2004 07:14 PM
Daniel
Aug 22, 2003 07:05 PM
Jockobo
Mar 19, 2003 04:49 PM
