HOw is this for an intercooler instead of a front mount??
Old Aug 22, 2006 | 12:34 PM
nuttybumpo's Avatar
Default HOw is this for an intercooler instead of a front mount??
http://cgi.ebay.com/ebaymotors...wItem
Thinking of using this instead of a front mount for 8psi daily driven
Old Aug 22, 2006 | 12:42 PM
Finland's Avatar
why would you want to? You are going to need a pump, a tank, a bunch of hose, then you'll have to play with flow rates and for sure measure inlet and outlet temps to dial that setup in properly. I'd just keep it simple and get a front mount.
Old Aug 22, 2006 | 12:55 PM
EX-T's Avatar
Default Re: HOw is this for an intercooler instead of a front mount?? (nuttybumpo)
It looks like a pretty good idea but it is pretty expensive.
Do it use it's own water supply or engine coolant?
Old Aug 22, 2006 | 12:57 PM
nuttybumpo's Avatar
Default Re: HOw is this for an intercooler instead of a front mount?? (EX-T)
uses a little front mount radiator and a pump.
Old Aug 22, 2006 | 02:15 PM
igo4bmx's Avatar
for a low hp build,i would go to air to air.
i was at a shop this weekend that works on vw and porsche's. They only use air to water setups, because the are so reliable.
the shop owner drove his car (twin gt30r turboed porrsche) for a 6 hour hard drive, and the air to water setup was still cool to the touch.
Old Aug 22, 2006 | 02:17 PM
JG-Fabrications's Avatar
Default Re: (igo4bmx)
Hey if you need a airwater setup I have a 100% complete setup (my old s2k setup) that when run on ice is good to 600whp I daily drove it with 465 whp though
It has everything (intercooler, water lines all aeroquip with fancy fittings, water pump, relay for pump, water resivor, radiator for daily driver use)
-James
Old Aug 22, 2006 | 02:22 PM
93supercoupe's Avatar
Default Re: (JG-Fabrications)
doesnt seem that hard, just find out the pump with the right output rate and the rest is self explanitory
gsrt
Dec 13, 2012 07:49 AM
94hondacivicvtec
Nov 6, 2007 05:56 PM
stretlegal
Jun 23, 2003 02:51 AM
vtec.dc2
Dec 23, 2002 07:58 PM
escapist13
Aug 22, 2002 05:02 AM
