Bad Idle after running hard >>
Car runs perfect normally, but sometimes after a couple of hard pulls it has trouble idling and sometimes dies. It always starts right back up with no problems.
The car never used to do this so I dont belive its something with the tunning. My bet is I need to change my plugs, but while im waiting for a new set to arrive I thought I would ask. Currently running BKR7E's @ .024 gap. They have been in the car for 500 or so hard miles.
Thanks,
platinum.
Thanks,
platinum.
Re: Bad Idle after running hard >> (boostedcivicsir)
Any pain in running the plugs until the new ones arrive besides degraded performance?
platinum
platinum
Re: Bad Idle after running hard >> (adictionbass)
Built Y8, 424whp...
more info here
https://honda-tech.com/zerothread?id=1622221
yes small gap, but thats with a stock ignition.
platinum.
more info here
platinum.
Re: Bad Idle after running hard >> (platinum00)
hmmm... im no d series guy, but im running ~16 psi on a t3 60-1 @ 9000 rpm with a bone stock ignition and plugs gapped at .030. Unless your running really rich (which according to ur dyno your not) a full boost run should clean off the plugs.
What is your AFR when its stumbling?
Not sure on the A/F. I dont have a wideband installed unless tuning. The narrowband is useless but it say RICH .
platinum.
platinum.
im going to let someone else chime in here, i dont want to tell you the wrong thing. But reasons like this are why i keep an extra set or two of plugs around
With ya... what are you thinking with the A/F.
The plugs were gapped so low because I was having serious issues blowing the spark about above 24psi.
thanks for the help
platinum.
thanks for the help
platinum.
yeah .024 is not that big of a gap i run .020 on my DD, it stumbles a lil after hard pulls idling but it doesnt die or anything....
I would wait for the new plugs...
Re: (platinum00)
Ran the car pretty hard today. Put about 150 miles on her
Idle is still not heathly sometimes. I cant really find a pattern to it yet.
Could the IAC cause this? I guess I need the wideband hooked up to see what the A/F is.
platinum.
platinum.
Re: (meanEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meanEG »</TD></TR><TR><TD CLASS="quote">its possible that something under heat is twisting/warping causing a leak, or a bad pcv vavle</TD></TR></TABLE>
Maybe, but its random and normally if I shut the car off and turn it back on idle is perfect again. PCV system has been removed and replaced with catch cans.
I will try and check my vac hoses when it happens again and see if I notice a leak.
Thanks for the input, keep it comming
platinum.
platinum.
Re: (platinum00)
I've had this same problem with my car for a while now. I've put new plugs in it and replaced every vacuum line on the car and it still does it. I turned the idle up to about 1K just so I wouldn't have to play with the gas so much at lights.
That's weird. I idle very well after runjing hard, but just cruisin the idle is a lil bumpy at least til I hit v-tec a few times then it purrs like a kitten at idle. Very confusing and sometimes frustrating.
Re: Bad Idle after running hard >> (97grnrs)
well I decided I need a new paint job, so the car is ripped apart again. No glass, moldings, lights, etc...
Might be a couple of weeks before I get her done.
If no one has a solution, I will buy a Wideband and post of the readings to help.
It sounds like a couple of people are having this problem, so at least it's not just me
platinum.
platinum.
trini-gsr
04-15-2007 05:20 PM
