how to install moroso oil pickup with moroso oil pan
anyone got pictures of how to install a moroso oil pickup? can't figure out where it goes and bolts up. pics would be sweeet. thanks
Re: how to install moroso oil pickup with moroso oil pan (B18 CYA)
it bolts to the location the original pickup bolted to and then it has a bracket thats attached to it that bolts to two holes...its only fits one way and the holes only line up with the right holes so unless you have the wrong pick up then your just not trying hard enough...the b16/ls/and b18c are all different pick ups so if you have one for the wrong motor its will NOT work.
bout 2 do oil pan removal/install.. gettin all my procedure verified first so dont run into any dela
J.nguyen
Honda S2000
05-12-2007 01:25 PM
