How high?
Old Oct 30, 2001 | 11:41 PM
Charles B.'s Avatar
Default How high?
How much boost/horsepower can a stock GSR bottom end handle? Given that its tuned well with fuel and ignition.
Old Oct 31, 2001 | 12:15 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: How high? (SuperDuperEG)
Stoopid did 12psi on a stock block with stand alone. Dont even think about doing this with a FMU.
art
Old Oct 31, 2001 | 12:24 AM
TurboIntegra's Avatar
Default Re: How high? (Arturbo)
I have done 1bar w/ stock block and stand alone. Its all about tuning baby!
Old Oct 31, 2001 | 01:00 AM
CM-R's Avatar
ben said this was ok with a stock gsr..is this right? its with a vortch FMU.....
As for safely boosting 10-12psi, I would recommend the following:
J&S Ultra Safeguard Version 2
RC 310cc Injectors
Vortech 8:1 Disk
With this combo, you can safely run up to 12psi.
Old Oct 31, 2001 | 09:30 AM
rtype11's Avatar
Default Re: How high? (CM-R)
your question is obviuosly about safe power and lbs - here is what you should not do: hook up nitrous fuel solenoid and jet to intake pipe and set on WOT for 100hp worth of fuel. - then lock wastegate with some big nasty old valve spring and go for blast at 23-25lbs boost on C16. we did this for fun on a car we were just gonna use for parts, felt like it made sick power probably 230- 240hp
CRXLST
Oct 29, 2004 07:50 PM
Rah Rah
Feb 24, 2003 06:03 PM
ludelvr
Dec 19, 2001 07:50 AM
Tr0LL
Sep 14, 2001 10:54 PM
not so civic
Aug 7, 2001 04:10 AM
