How good would it be to boost this?
Old May 28, 2003 | 04:20 AM
AzN_Flava's Avatar
Default How good would it be to boost this?
My friend and I were just debating, about boosting a ls/vtec. Just curious if this has what it would tkae to get an integra into high 12's on azenis tires...
b18b b16a2 head, 10.8 compression ratio, probe rods, itr pistons, gsr cams, b16 tranny, and hondata.
Assume the turbo is either a t3/t4 .63 or a t3 60-1. I guess the integra weighs in at 2500 without driver.
How good do you think this motor would be to boost? How much power do you think it can make so the itr pistons wont blow? Just outta curiousity..
No changing any of the above mentioned block parts, but the turbo stuff is all up in the air...
Lets hear the guestimate times and guestimate powers.
Old May 28, 2003 | 10:04 AM
FastNFurious
Guest
Posts: n/a
sure you could hit high 12s with alot of tuning
you would probably need like 15-20 psi.
Old May 28, 2003 | 10:23 AM
platinum00's Avatar
Default Re: (David555)
if the ls/vtec is built correctly then boosting it is no problem. most use lower compression then that when building, but not a issue if you get your tuning down. if you have hondata should not be a issue.
platinum.
Old May 28, 2003 | 10:32 AM
pissedoffsol's Avatar
25 Year Member
Default Re: How good would it be to boost this? (AzN_Flava)
<rant>azenis aren't drag radials. Why does everyone keep thinking that? </rant>
anywho, yeah, your compression is kina on the high side for boost, but if you get a GOOD tune on it with your hondata, you should be fine. and with the extra compression, you will make a lot of power at a lower boost level than a lower CR counterpart.
Old May 28, 2003 | 10:40 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: How good would it be to boost this? (pissedoffsol)
Not a problem in getting in the 12's, just restating what everone else said, if it's built correctly you wont have a problem.
Old May 28, 2003 | 02:21 PM
AzN_Flava's Avatar
Default Re: How good would it be to boost this? (HybridcivicLS-T)
how much power do you think i'll need to make to hit high 12's?
Yah, i know 10.8 is high, but i like how R's are boosted, and 10.8 doesn't seem too much of a difference from 10.6...
Old May 28, 2003 | 03:43 PM
intekragsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzN_Flava &raquo;</TD></TR><TR><TD CLASS="quote">how much power do you think i'll need to make to hit high 12's?
Yah, i know 10.8 is high, but i like how R's are boosted, and 10.8 doesn't seem too much of a difference from 10.6... </TD></TR></TABLE>
2 points is kind of a big difference. I hope you plan on running race gas with that compression and goals. On the street, you will have to run very low boost.(suggested)
Anyway what makes you choose such a high compression? Just curious. I am sticking to 10:1 since it seems in the mid range of high and low comp.
Old May 28, 2003 | 03:48 PM
AzN_Flava's Avatar
Default Re: How good would it be to boost this? (intekragsr)
i chose that b/c i like how boosted R's have performed...
I didnt know .2 would have been that much of a difference...
well here we have 94 octane if that makes a difference
i heard i need 400whp? is this true to hit hihg 12's on street?
Old May 28, 2003 | 03:52 PM
intekragsr's Avatar
ive seen people with 300-350 hit mid 12's
Old May 28, 2003 | 03:55 PM
b16ahybrid's Avatar
i heard i need 400whp? is this true to hit hihg 12's on street?</TD></TR></TABLE>
Nope, your can hit high 12's with about 250whp and slicks. I'm on the verge of 12's as soon as i find a set of decently priced slicks.
Thats for a civic coupe weighing about 2,500lbs w/driver
hatchyboy89
Aug 7, 2012 06:30 PM
turbosleepa
Sep 13, 2009 04:47 PM
vtec25
Jun 5, 2006 12:30 AM
93b16delsol
Aug 16, 2005 06:34 PM
z6
Apr 9, 2004 06:51 AM
