will this turbo work?
Old Aug 5, 2012 | 08:40 AM
hatchyboy89's Avatar
Default will this turbo work?
ok i have a ls/vtec with 81.5 jdm b16 pistons in a b18b block, ls crank wit shoot pin'd ls rods acl bearing, then on top is a b16a head with gsr cams and a type r intake mani. it will hanging from a ranhorm mani,
ok now the ? is will a Air Research t3 turbo Specs are: 42.5mm inducer, 60mm exducer compressor (50 trim). 58mm x 47.5mm exhaust .48 ar Exhaust. FORD 5 BOLT EXHAUST, how will it do wit my set-up? thanks
Old Aug 5, 2012 | 02:40 PM
TheShodan's Avatar
Moderator
Default Re: will this turbo work?
Depends upon power level desired. Can't do more than 300whp. Falls off above 7000 rpms
Old Aug 6, 2012 | 07:30 PM
wantboost's Avatar
Who is Mr Robot?
lolol shoot pin'd... what the **** is that?
do you mean shot peened?
Old Aug 7, 2012 | 06:30 PM
Hyper16-Johnny's Avatar
You can boost any motor but with with an approx compression of 12.3:1, I'd say otherwise. I'd say stay allmotor and throw in some stage 2 cams and make 220-230hp. You'd be happy with an allmotor setup of that status, it would probably be quicker in the 1/4 then if you were to boost. It might not be as fun on the fwy but boost with that compression and on cast pistons not a good idea.
subman20
Oct 9, 2013 07:55 PM
pkilla
Jan 12, 2007 06:27 PM
choko
Aug 10, 2005 08:17 PM
AzN_Flava
May 28, 2003 03:55 PM
