How does the sensor component of the J&S knock sensor function?
Old Apr 20, 2002 | 05:12 PM
bruthaboost's Avatar
Default How does the sensor component of the J&S knock sensor function?
I'm wondering cause as I was installing the J&S and looking for a spot to install the sensor, I accidentally shorted it a bit. Well it smoked. I let it touch the alternator's live wire-I know I know I'm a dumbass for not disconnecting the battery for any under hood work-and the engine block. Thus forming a path to ground. It sparked and a little smoke wisped up to my horror. I'm wondering if there any components in there that are sensitive to voltage/current.
I checked the resistance and it was 3.8k or 38k. I'll check again later.
Muchos gracias
Old Apr 21, 2002 | 12:15 PM
hatchy's Avatar
Default Re: How does the sensor component of the J&S knock sensor function? (b18bpwr)
The sensor is basically a microphone, and if you saw it smoke, there is a good chance you fried it.
Old Apr 21, 2002 | 01:04 PM
John_at_J&S's Avatar
Default Re: How does the sensor component of the J&S knock sensor function? (hatchy)
The sensor is a crystal, but is has a 3.9 k resistor to ground. That shouldn't have fried it.
SuperBowser707
Dec 4, 2012 07:49 AM
FunIntegras
Oct 2, 2005 06:00 AM
SC94DB8
Oct 22, 2002 11:16 AM
