How do I make a MAP diffuser w/ check valves and Ts????
This is the last step in my turbo install. Its a Rev Hard 2C on an LS motor. How do I construct this device? I have 5 Ts and 4 oneway valves provided by revhard. Do i block off the hole that the MAP sensor goes into on the TB? I assume you put this contraption between a boost/vac source and the nipple on the MAP sensor. right? thanks
Re: How do I make a MAP diffuser w/ check valves and Ts???? (B18B EK)
Also if anyone knows the website of that kid on Ebay that sells info on making turbo kits for hondas that has a diagram of the MAP diffuser. thanks
bump
click here http://www.cse.uconn.edu/~yelevich/turbo/turbo.html and scroll down. hth.
Re: How do I make a MAP diffuser w/ check valves and Ts???? (SuperDuperEG)
Thanks, your the man!!! time to start it!!!
no prob, good luck and happy boosting! https://honda-tech.com/forums/images...es/emsmile.gif
damn thats a good site https://honda-tech.com/forums/images/smilies/emthup.gif
