how to the condition
Old Jan 31, 2005 | 01:08 PM
PFSeg's Avatar
Default hot to tell condition
i'm going to look at a t3 turbo and intercooler of a turbo coupe on saturday, guy wants $175 for both. just wondering what all to look at when trying to tell what condition the turbo is in. thanks
Old Jan 31, 2005 | 01:43 PM
PFSeg's Avatar
Default Re: hot to tell condition (PFrex)
bump
Old Jan 31, 2005 | 01:46 PM
PM-Performance's Avatar
Old Jan 31, 2005 | 01:49 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: hot to tell condition (itr206)
buwahaha, Pwned
Old Jan 31, 2005 | 01:53 PM
OK , now i got that outta my system. Check for shaftplay in the turbo. Look for oil around the housings and wheels and inlet and such. Honestly it sounds too good to be true.
The IC have it pressure tested. look for dents and such
Old Jan 31, 2005 | 02:01 PM
PFSeg's Avatar
not sure what shaft play is and do i want oil around the housing and wheels and such?
Old Jan 31, 2005 | 02:09 PM
EJ1 wilcox's Avatar
Grab the end of the shaft and wiggle it around a bit... (you know which shaft right?)
Wiggle it both in/out and up/down, there should very very little movement...
Check the wheels for excess oil and buildup... make sure the shaft spins freely...
shadow103rd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">OK , now i got that outta my system. Check for shaftplay in the turbo. Look for oil around the housings and wheels and inlet and such. Honestly it sounds too good to be true.
The IC have it pressure tested. look for dents and such</TD></TR></TABLE>
Put you finger in the exhaust outlet and if you get oil on your finger, then the turbo seals are gone. Same with the compressor housing.
Shaft play is how much the wheels and shaft moves. Its okay to have a little bit of shaft play (moves up/down/left/right) But the turbo is dead if the Shaft moves in and out.
Jon
Old Jan 31, 2005 | 02:19 PM
PFSeg's Avatar
thanks guys
Jbur074
Dec 25, 2007 10:54 AM
Sprockets
Jun 7, 2005 07:38 PM
ArchAngel Sabastian
Jan 23, 2004 12:29 AM
11psiTurboSI
Jul 20, 2003 09:44 AM
boostin b16
Feb 11, 2003 05:52 AM
