Moroso oil pan>>>>???
check this out... im thinking about gettin a moroso oil pan. but the web site said it holds 5qt. off oil... i only but 3.7qt. in my car.... with that oil pan will i have to add more oil or what... what do you guys think?
Re: Moroso oil pan>>>>??? (flipstar760)
well, the moroso oil pan is larger in size which would carry more oil!
if you are going n/a this would not be neccesary at all. The reason why people use it is because of the trap doors it incorporates inside for better oil availability around sharp turns, fast accelerating, or fast braking.
the other reason why people use moroso oil pans is so that they dont have to weld oil bungs for your turbo drain onto your oem pan. also some people mount oil temp sensors on their moroso oil pan aswell.
this is why you see two bungs on their 1 for turbo oil drain and the other for oil temp!
Location: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
1 Post
Re: Moroso oil pan>>>>??? (rip94delsol)
a lot of people like them cause they are baffled as well don't know what your intentions are but i've the only thing bad i read about was people losing OP taking sharpe turns autocrossing....
Re: Moroso oil pan>>>>??? (Throwdown)
the reason why im getting it is because im only paying $40 in the box unopened so i can still put 3.7qt. in my motor? what will the dipstick read?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipstar760 »</TD></TR><TR><TD CLASS="quote">the reason why im getting it is because im only paying $40 in the box unopened so i can still put 3.7qt. in my motor? what will the dipstick read?</TD></TR></TABLE>
Yes,you wil need to put 5 qts. in your stolen oil pan.The pan uses a longer oil pump pick up tube.You should be able to find a stolen one of those for $1.The dipstick reads full after you put 5 qts. of stolen oil in it.
OMFG. Of course, you're going to have to add more oil. You have to add enough oil so it shows the oil at the same position on the dipstick. Whether that's 3.7 or 6 quarts. Add however much oil you need to to get the dipstick to read "full".
He's right about the pickup too. I'm thinking about paying FULL PRICE for a canton oil pan for my B16. Going to be running R-Comps and a turbo next year so, I need the trap doors, the extra oil AND the oil bungs.
1 Post
Re: Moroso oil pan>>>>??? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR »</TD></TR><TR><TD CLASS="quote">
Yes,you wil need to put 5 qts. in your stolen oil pan.The pan uses a longer oil pump pick up tube.You should be able to find a stolen one of those for $1.The dipstick reads full after you put 5 qts. of stolen oil in it.</TD></TR></TABLE>lol i don't care who you are thats funny
1st of... you need to kick back with that stolen sh*t... im friend own me alot of money and he cant pay so thats how im getting it....
do you know what model the pan is? some pans are made for specific engines! for sure you will need the moroso oil pick-up tube! i think they sell for around 40$.
also when you add oil start at 4qrts then check the oil if needed go in incements of 1/2 till you get the dipstick to read full!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flipstar760 »</TD></TR><TR><TD CLASS="quote"> Yes,you wil need to put 5 qts. in your stolen oil pan.The pan uses a longer oil pump pick up tube.You should be able to find a stolen one of those for $1.The dipstick reads full after you put 5 qts. of stolen oil in it.
1st of... you need to kick back with that stolen sh*t... im friend own me alot of money and he cant pay so thats how im getting it....</TD></TR></TABLE>
Then I guess its costing you a lot more than $40.
Sprockets
08-08-2005 01:53 PM
