How to Cancel IAC for Direct Port
F20B Direct Port
hi,
is it possible to cancel it from the Intake and just plug it so it doesnt throw CEL, im doing this because i want to do direct port
no worry about the idle its just a drag use car
Modified by CiViC SiR at 5:44 PM 3/24/2005
yeah you can, just make a block off plate for the manifold, and then the same plate for the iIACV with 2 brass nipple fittings threaded into it, then give it vacuum before and after the TB just like the way it is supposed to work, and just relocate it somewhere else.
what motor is that? and what chassis?
or take the manifold off and do it from the bottom
Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">
delsol with f20b
delsol with f20b
yeah that will work fine, its after the butterflies. there is a post on here about the IACV, alot of guys running the ITBs have to relocate the IACV somewhere else, and to do it costs like 5 dollars, a piece of metal and some fittings
bottlefedintegra
11
11-19-2003 06:20 PM
