IAC fix?
IAC fix?
well i heard that you can "block off" the iac and it wont idle surge this being half true.
i blocked mine off and left it pluged in ..
dose anyone knwo how to make the CEL go away?
has anyone els done this?
any help wold be apreacated
Re: IAC fix? (B16 delSlow)
Did you make a plate for the manifold and just leave it hanging? I've also been thinking about this since I live in a climate that never drops below 45 degrees.
Re: IAC fix? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Did you make a plate for the manifold and just leave it hanging? I've also been thinking about this since I live in a climate that never drops below 45 degrees.</TD></TR></TABLE>i made a plate and it idels fine but i need to find out how to make the CEL go away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">What does the ECU look for when the IACV is normally attached? Vacuum levels or temperature, or a combination of both?</TD></TR></TABLE> i dont know the cel dont coem on till i rev it or drive it..also mine is obd1
TheAutoboxer
11-01-2003 06:46 AM
