how to adjust Vortech Bov?
Old Feb 7, 2004 | 05:16 PM
TURBODC4TEG's Avatar
Default how to adjust Vortech Bov?
well i'm not dumb just need straight facts, i was told that if the bov was to loose i could lose boost pressure during full boost? what is the best way to set it up? Right if i drive normal and hit 1-3 psi it will blow off ( i think its to lose). My instructions say the spring adjuster should be left fully backed off as supplied, well when my friend decided to play with it and i never messed with it sense i just want it normal.
the instructions also say it can be adjusted 3"Hg(spring adjuster all the way out) to 6"Hg(spring adjuster 1/8" above the jam nut. The Blowoff valve opening point is set as 16"Hg. (spring adjuster all the way out) and should not be increased.
so can anyone help me out plz
here is a link of the directions, u will have to have adobe reader
http://www.vortechsupercharger...m.pdf
Old Feb 7, 2004 | 06:26 PM
Default Re: how to adjust Vortech Bov? (turbolsteg)
anyone
Old Feb 8, 2004 | 01:10 AM
Old Feb 8, 2004 | 08:11 AM
ClubSiRacer's Avatar
The more you tension the screw on the back, the tighter it will be and the more vacuum it will take to open. Honestly, it should be loose enough to open fairly quick out of boost and release all of the pressure but where that setting is will be different for everyone. Just tweak the bolt on the back until you are satisfied. And remember, it also needs a vacuum line from the manifold after the throttle body to the nipple on the back to properly function.
Old Feb 8, 2004 | 02:48 PM
Default Re: how to adjust Vortech Bov? (ClubSiRacer)
thanks, anyone else?
is the losing boost true or false it ur bov is to loose? and that it shouldn't blow off under low boost (1-3 psi)
Old Oct 18, 2010 | 10:41 PM
Dave.HR's Avatar
I have a situation where my Vortech is making noises like a rattle snake in 4th and 5th gear in full boost.
Which way do i need to turn the screw to tighten the spring? Clockwise or counterclockwise?
Thanks!
Old Oct 19, 2010 | 03:10 PM
95skunkedgsr's Avatar
Thanks!
lefty loosy righty tighty i belive....
jacob4lester
Feb 15, 2010 05:30 PM
ITRICED
Mar 4, 2009 09:33 PM
khmboostedeh2
Sep 25, 2006 11:30 AM
PUREVIL
May 20, 2003 09:13 PM
Liltrix
Nov 25, 2001 09:58 PM
