hondata USB
Old Mar 25, 2004 | 08:34 PM
JrCRXHF's Avatar
Default hondata USB
i have a new laptop that is a amd 64bit and i just got my car out and well my laptop does not have a serial port no big deal i will just go buy a serial to usb port well it when hooked up to my data logger i can only see my tech the other gauges are just maxed out and do not move at all. anyone have a idea.
Old Mar 25, 2004 | 09:18 PM
Silverbeast's Avatar
Default Re: hondata USB (JrCRXHF)
Try to double check the com port settings on the logger and make sure that it's correct.
What OS? What Hondata System? ECU?
Old Mar 25, 2004 | 09:28 PM
birz's Avatar
Default Re: hondata USB (Silverbeast)
no everything is designed to be serial+ usbat the same time,, for example there are some mice that you can't plug them with a usb to serial adaptor, it's just not designed to do so. I dont know about hondata, but it might be the problem.
Old Mar 26, 2004 | 09:34 AM
JrCRXHF's Avatar
Default Re: hondata USB (birz)
yeah all it reads it the tech it and i know it is spose to run on com port 4 so i guess i will have to check with my hondata dealer and find out. i just just wondering if anyone else has experneced this.
Old Mar 26, 2004 | 09:36 AM
Bailhatch's Avatar
can't you just reasign the ports in your BIOS?
Old Mar 26, 2004 | 10:01 AM
JrCRXHF's Avatar
Default Re: hondata USB (Bailhatch)
yeah i don't think the port is the problem i just don't think the hondata will talk to the usb maybe it is the belkin usb/serial port one that i have. it is spose to be for cell phones and pda's there might not be enought band width
Old Mar 26, 2004 | 10:59 AM
dabrown's Avatar
I am using the same belkin for my hondata setup and it reads just fine.. However I had to uninstall the Hondata software and call them up then reinstalled it... It should work for you..
Old Mar 26, 2004 | 11:05 AM
Muckman's Avatar
Moderator in Chief
Ive heard bad things about the USB to serial adapters working with the AEM EMS. Maybe you can get a PCMCIA card with a serial dongle? shoulda gota cheaper laptop
Old Mar 27, 2004 | 09:16 PM
JrCRXHF's Avatar
Default Re: hondata USB (Muckman)
yeah well this laptop was only 1300 bucks and with the amd 64bit and a ATI 9600 and wide screen one could not ask for more. but that was its only down fall there are more and more laptops that do not come with them. but oh well i know it can be done i just might have to buy another one that runs faster.
Lan
Jun 28, 2006 07:16 AM
eg crunkmonster
May 11, 2006 07:24 AM
turbotime
Oct 10, 2005 11:56 AM
Brian_92GSR
Nov 15, 2001 01:58 PM
