uberdata compatability
Old Mar 27, 2004 | 07:16 PM
tonezilla's Avatar
Default uberdata compatability
after searching on here and the uberdata forum . it doesnt seem that most people use uberdata for turbo'd f/h series setups . i wanted to know if uberdata is compatible with an h23 ?! if so which ecu would i use and start with ?! also is anyone using uberdata on their f/h series turbo setups ?! how much power are u making at what psi ?! are you having any problems with it as well ?!
Old Mar 27, 2004 | 07:17 PM
ITSTOCK's Avatar
Default Re: uberdata compatability (redxalien)
Uberdata is only compatable with p72 p75 p30 p28 and po6 i believe.
Old Mar 27, 2004 | 07:22 PM
5STAR3's Avatar
Default Re: uberdata compatability (ITSTOCK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSTOCK &raquo;</TD></TR><TR><TD CLASS="quote">Uberdata is only compatable with p72 p75 p30 p28 and po6 i believe.</TD></TR></TABLE>
right but.....
you can make the map however you want it. So you could make a map using one of the above ecu's that would run your car.
i know they do it, i dont know which ecu they like to use.
Old Mar 27, 2004 | 09:20 PM
tonezilla's Avatar
well i seen about 1 or 2 posts about h22a map . butt i noticed it would say something about running too rich . i also seen some maps from gimpy also . butt he stated that when he made the maps it was for reliabilty issues and not for performance since it was an old motor . plus i remember he said something like his map was running really rich and he never fixed it because it he doesnt own an accord anymore .
so out of those ecu's which would be my best bet to go with and start a map with on an h23 ?!
F20_EG6
Jan 3, 2008 04:36 PM
cbmprelude
23
Jun 11, 2006 08:01 PM
Rus1an
Dec 27, 2005 12:44 PM
dominate9
Nov 24, 2003 01:26 PM
