Hondata S100 with Boost and a VTEC Ecu? Will it work on a None VTEC
Old 02-04-2004, 08:06 AM
Quad-Damag's Avatar
Default Hondata S100 with Boost and a VTEC Ecu? Will it work on a None VTEC
I got a 2000 honda civic dx, and this guy emailed me and we talked, he has a Hondata S100 with a OBD 2B to OBD 1 Harness and a P28 Ecu already chiped ( It's the 92-95 ex/si ecu
Will it work on my 2000 Honda Civic DX, do i just not connect the vtec wire, or will i have to open up the ecu and take the vtec out? Or can i just plug it in and it will work fine. Please let me know asap. I just don't want to throw a code or have the car runing shitty
Im runing blue box right now, and i need something tuneable, this is a good deal, i don't want to pass up.
Old 02-04-2004, 11:44 AM
Quad-Damag's Avatar
Default Re: Hondata S100 with Boost and a VTEC Ecu? Will it work on a None VTEC (Quad-Damge)
Anyone?
Old 02-04-2004, 01:23 PM
New User
psileepR's Avatar
dont quote me but i believe u will be fine.
I dont know if u can disable vtec, but if worse comes to worse vtec can be set say at 10k rpm where you will never hit and you will never go to the vtec fuel/ignition maps.
if i am completely wrong i apologize.
Old 02-04-2004, 01:44 PM
Silverbeast's Avatar
Default Re: Hondata S100 with Boost and a VTEC Ecu? Will it work on a None VTEC (psileepR)
Yes you can disable vtec within the Hondata Rom.
Any dealer can do it for you.
Old 02-04-2004, 02:05 PM
ghettocrxsi's Avatar
Default Re: Hondata S100 with Boost and a VTEC Ecu? Will it work on a None VTEC (Silverbeast)
You will just have to have a non vtec rom burned from any dealer. If you use the vtec program it will run rich and pretty shitty. But that s100 will work!
Old 02-04-2004, 02:59 PM
Jefnes's Avatar
Sure, it will work just fine.....
You still need it tuned, but once tuned you'll have no problems.
Jeffrey Atwood
95ITRJDM
Engine Management and Tuning
04-25-2011 12:03 PM
stpacura
03-10-2008 10:09 AM
Andres-eh2
05-18-2006 12:10 PM
TurboIntegra
12-15-2002 12:57 AM
Quick Reply: Hondata S100 with Boost and a VTEC Ecu? Will it work on a None VTEC
