Hondata Red Led blinking , Engine will not start Help me.......
Hello
I have a Crx 1991 DOHC V-TEC 150PS with Turbo and Hondata P28 with S200 (Boost,Datalogg.), 440ccm Peak and Hold Injectors, OBD0 to OBD1 Conversion Harness, M-300 Wideband
The following problem:
I would start the first time (after the turbo change).does not start however.
1.gasoline pump does not start(is however not so bad, Relay bridges)
2.The red Led in the S200 blinking slow
3.The injectors have permanently Ground and Power (They hum completely quietly) even with taken off key.
I have a orig. Hondata P28 and a friend provided the chip, Used also another chip, resembles problem.
Ignition functions however!!
What could be???????
Hope you can understand which I mean.
Thanks Nico
Thanks Nico
Re: Hondata Red Led blinking , Engine will not start Help me....... (maxspeedhonda)
Hi,
It has a suitable Basemap, with the other chip it does not work!!
A Friend has a Civic 1993 1.6 SOHC V-TEC with a P28 ECU......I can take to try???
Thanks Nico
Thanks Nico
Re: Hondata Red Led blinking , Engine will not start Help me....... (CRX RACER)
Flashing LED means bad map. Thats kinda vauge so either try a different map, ECU, or try to modify the map you have in the options (i.e turn off o2, heater, ect).
Re: (turboda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboda6 »</TD></TR><TR><TD CLASS="quote">try converting to uber. </TD></TR></TABLE>
Shut up.
Shut up.
Re: (nsxmatt)
check all the connections between the hondata box and the ecu as well i had problems pulling out the connector from my ecu...also make sure the chip is in all the way...you did try two diff ecus so i doubt this is the problem but its worth a try
Re: (CycloneBlue_1.6EL)
Hi,
I have the stock P28 ECU from the Civic SOHC V-TEC attached and he started !!
Did not run well, but is because of the characteristic diagram.
The ECU or the s200 is defect !?
I that normal with one orig. Hondata ECU, that outside at the ECU P28-obd1 stand and inside on the socket P06 stands.Is a Original Hondata ECU with the black sheet metals.
Thanks Nico
Thanks Nico
Re: (dustin)
Yes, a zero value resisor is fine.
If your injectors are humming withteh ignition turned off, you have some kind of wiring problem in the car.
You sure the injectors are humming?
When I've f-ed something up with Hondata etc (like pulled the chip out with the ign ON! haha) the IACV always makes a buzzing/humming sound... not the injectors.
Re: Hondata Red Led blinking , Engine will not start Help me....... (boostedcivicsir)
Hello,
What and where is J1 ???
the injectors hummed, because they had permanently tension.
Who sells a P28??
Where I find a guidance for the change of the P28.I have the base from the chip and the resistors.
Thanks
Nico,
Who sells a P28??
Thanks
Nico,
