Hondata s100 help
I got my hondata s100b and p28 socketed a while ago and tried to start the car with it today with no luck. The car won't start and when the was no light on the s100 unit. Has anyone run into this problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c »</TD></TR><TR><TD CLASS="quote">Do you have a start up map loaded on the chip? Wait, do you even have a chip in the p28? the s100 led should be lite up. </TD></TR></TABLE>
not sure if i got a start up map but i did get a base map from kyle for my setup...is that the same thing? And the p28 was socketed and chipped with the chip that came with the s100 at nrgtech.
yup i made sure all the wiring was ok. the harness was from blown90hatch and i'm pretty sure his work is good. The stock harness was fine because it started up with the stock ecu...i hope my ecu is ok and that its something minor ( crosses fingers)
CRX RACER
Mar 29, 2005 10:41 AM
