Hondata problem, Help needed...
Old Aug 13, 2003 | 05:39 PM
TeH PLAYA's Avatar
Default Hondata problem, Help needed...
what up FI freaks
the car: I'm running a b16 w/ JRSC @ 12lbs (as indicated by boost gauge), s200, rc440's, p28 ecu, GM 3bar map sensor.
problem: basically the car does not accelerate at WOT pass 6600rpm. But if I give it partial throttle (ie. 3/4 throttle) it will go to redline (8100rpm). Full throttle shifting works perfectly if I do it on partial throttle. Now if I try to do it with the pedal to the metal, like how you're supposed to, the car cuts out like I hit a brick wall and does not accelerate. The CEL flashes until I let go of the gas.
Basically if I take it pass 6600rpm on partial throttle then mash the gas at lets say, 7000, the car dosent accelerate. All I hear is the charger but not the motor itself.
I have the clutch switch installed. I made sure my foot was off the clutch.
Hondata interface light does not blink. Stays on the whole time.
Also, static rev setting does not work for ****. I did it per the instructions, no dice. For instance, if I try to set the launch via static setting, it always gives me 1600rpm, no matter what combination of the push button/brake pedal I do.
Dynamic rev setting works perfect.
Would incorrect installation of the 3bar map sensor cause the car to do this?
Would I have hit the boost cut?
I don't have any of the software. If it is a software problem, will anyone in the Bay Area help me out who has datalogging/hondalogger?
It didn't do this on the dyno. It went to 8100rpm at WOT while being dyno tuned.
I can come back to my tuner (DSR) and tell him about it... but my work schedule sucks and I have no time during the week.
I'll mess with the car again tonight and see what I come up with.
Any ideas guys?
Old Aug 13, 2003 | 05:52 PM
accordfreak's Avatar
Default Re: Hondata problem, Help needed... (THE PLAYER)
where did lawrence set the boost cut at on the hondata?
Old Aug 13, 2003 | 05:58 PM
TeH PLAYA's Avatar
Default Re: Hondata problem, Help needed... (accordfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordfreak &raquo;</TD></TR><TR><TD CLASS="quote">where did lawrence set the boost cut at on the hondata?</TD></TR></TABLE>
you know what, good question. I didn't ask him when I was there
I will call him in the morning.
Old Aug 13, 2003 | 06:03 PM
ladysman's Avatar
I think that is what it is too. Although something with the full throttle shift is my second guess. That is what it was for me. I ended up wiring a switch for daily driving to turn it off.
Old Aug 14, 2003 | 01:16 PM
Spunkster's Avatar
Also make sure that your map sensor is getting boost readings from the manifold and not from the throttle body.
Old Aug 14, 2003 | 05:35 PM
TeH PLAYA's Avatar
Default Re: Hondata problem, Help needed... (Spunkster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster &raquo;</TD></TR><TR><TD CLASS="quote">Also make sure that your map sensor is getting boost readings from the manifold and not from the throttle body.</TD></TR></TABLE>
checked that, and it's getting the vaccum/boost from the manifold.
spoke w/ Lawrence @ DSR, and my boost cut is set at 11. I will stop by DSR soon to have the cut disabled or increased. Hopefully that is it. Will keepyou guys posted
Old Feb 17, 2004 | 11:18 PM
prestonpark's Avatar
man i have the same problem i dont even use my 3 step any more on my hondata whne i pug it in i cant rev passed 6 no i just unplug it i rev it freely
chewyv
Engine Management and Tuning
Apr 17, 2017 07:19 PM
krc91987
May 26, 2014 11:05 AM
turbotime
Oct 24, 2005 09:11 AM
92WhiteEG
Feb 10, 2005 11:15 AM
Aeka GSR
Apr 28, 2004 09:26 AM
